Pushrod Problems GT40P Swap
Old 03-19-2018, 06:48 PM
baddad457's Avatar
baddad457
baddad457 is offline
Originally Posted by 80ford100
So it has been a while since I have posted thanks to work and other matters but I have finally made some headway, or at least made up my mind. Summit and Comp Cams were excellent with their customer support and they warrantied me a new cam and lifter set no questions asked. This has obviously made up my cam choice because of budget reasons. With the money I had saved for the roller conversion I purchased a used set of Trick Flow twisted wedge 170 heads with 2.02 intake and 1.90 exhaust valves and a 61cc combustion chamber completed with 1.6 ratio Trick Flow roller rockers and 3/8 studs with 5/16 pushrod guide plates. I am sending the engine down to Charlie Philips at Lone Star Machine Shop in FairField, Texas to be built. Looking for about 10:1 compression with a .060 over bore and either hyper or forged pistons. I would Like to do a small shot of nitrouse in the future.
I think you'll be limited to Trickflow's pistons with those heads, not to mention the cam too, I'm assuming the same cam ? Make sure they inspect the lifter bottoms and verify they rotate freely in the bores.
  #32
Old 03-20-2018, 10:41 AM
80ford100's Avatar
80ford100
80ford100 is offline
Trick Flow does seem to have some affordable forged pistons offered in flat top and dished. Since they are relieved for their twisted wedge heads those will more than likely be chose. Yes, the cam is still the Comp 280H grind. Any estimates on power number? My guess maybe 320 hp?
  #33
Old 03-20-2018, 04:36 PM
Justin Jones's Avatar
Justin Jones
Justin Jones is offline
I think the heads are an awesome move! But IMHO, I do think the flat tappet cam is the wrong way to go. I know you got it warrantied which made the choice easier. Earlier, you mentioned Howards. Howards lifters are made by Morel which is a division of Callies. Morel makes the best link bar lifter out there. Something that might ease that transition is looking for a used roller cam. A lot of the Mustang guys will use the Trick Flow cams over a Ford letter cam. You might be able to check over on Corral.net in the 5.0/5.8 engine parts classified section to see if they have something of interest to you.
  #34
Old 03-21-2018, 02:10 PM
80ford100's Avatar
80ford100
A buddy offered to buy the Comp 280H from me so I'll prob sell it to him and use the money for a roller cam. What do yall think of the Trick Flow Stage 3 cam?
Specs:
Summit Racing Part Number:TFS-51403005
UPC:842645110740
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:3,400-7,000
Intake Duration at 050 inch Lift:250
Exhaust Duration at 050 inch Lift:254
Duration at 050 inch Lift:250 int./254 exh.
Advertised Intake Duration:312
Advertised Exhaust Duration:316
Advertised Duration:312 int./316 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.595 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.595 in.
Valve Lift with Factory Rocker Arm Ratio:0.595 int./0.595 exh.
Lobe Separation (degrees):110
They also have the same lift offered in .304/.308 duration as well.
  #35
Old 03-21-2018, 03:20 PM
Justin Jones
That's probably too much cam for this application. If you stick with the series of Trick Flow cams, I wouldn't go over the Stage 2.
  #36
Old 03-21-2018, 03:58 PM
baddad457's Avatar
baddad457
Specs:
UPC:842645110740
What are you putting this in and what do you want out of it ? Looks to me like you're building a high rpm screamer for a farm truck. Also, What intake and carb are you planning on running ? If this is going in a steet driven truck, it's going to be VERY disappointing until you hit 4000 rpms.
  #37
Old 03-21-2018, 04:08 PM
80ford100's Avatar
80ford100
Truck is a weekend cruiser and will see some track time. It is a 1980 F100 2wd Long bed with a 3/5 drop. Trans is a World class T5 out of an SN95. 8.8 rear end with full spool and 4:10 gears. Running and Edlebrock RPM Air Gap intake. Have an MSD 6A ignition and Pro Billet distributor. Haven't completely decided on a carb or size yet. Will be running forged pistons for a small shot of spray in the future. Going to use ARP hardware in the bottom end. Shooting for 10:1 compression and 93 octane pump gas.
  #38
Old 03-21-2018, 09:14 PM
baddad457's Avatar
baddad457
Nice truck. I was thinkin you were putting all this on a 302. I went back and refreshed what you were doing. . Are those new Coopers ? Last set I bought (235/70 and 275/60) were crap. Both 275's came apart, the first sitting in the carport the day after they were mounted. The second came apart a week or two later. The 235's were out of round so bad that I had to replace both in a few months time. I've run these tires for thirty years (Hercules, Coopers and Mastercraft ) and they were fine until that last set I bought 5 years ago. Never again. I switched to BFG radial T/A's and they were not much better. I've since gone to Kuhmo and Toyos. Don't know where they're made but all the others are "Hecho in Mexico"
  #39
Old 03-25-2018, 10:44 AM
Earl0421's Avatar
Earl0421
Earl0421 is offline
Cam suggestion
i am using a Comp Cams 512 lift 220 duration cam and it’s building CRAZY power from 2,000-6,000 RPM then kinda falls on its face. But, thats the RPM range I want for my “sleeper” build anyway so I LOVE this cam!!! Its a Extreme Energy camshaft. I also have the “sewing machine chatter” and am running 1.7 roller rockers. The chatter doesn’t bother me much as the sweet sounding 3” exhaust with flomaster 40’s hides that sound (unless the hoods open) so you don’t even notice it. At the end of the day I call it a WIN.
79fordrat
06-17-2014 02:38 PM
timbersteel
01-22-2012 07:47 PM
65'f1004x4conver
57
12-07-2006 03:05 PM
a4x44ted
04-25-2006 02:46 PM
whd507
16
09-10-2002 06:46 PM
Quick Reply: Pushrod Problems GT40P Swap
