Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Is this Brake Drum Useable??
Old Feb 13, 2018 | 08:56 PM
252slater's Avatar
252slater
This is off the rear of my 68 F-600. I'm in the middle of doing rear wheel cylinders, brake shoes and springs/hardware. Also doing the rear wheel bearings while I'm there. Looks like it's been pretty hot.... is it still usable?
Also, i was able to coax NAPA into getting all the parts except the axle seals and two gaskets that sandwich them. Any idea where it get these? The axle is an Eaton model 13802 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity
Thanks in advance.
Old Feb 14, 2018 | 08:34 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I think you'd need to get that cut to the point where the cracks are gone. If they're too deep, it's trash.
My opinion. Others may differ
Old Feb 15, 2018 | 08:48 AM
252slater's Avatar
252slater
Using the drums as-is for now. Only local shop that could turn them said the lathe would most likely tear out big chunks and by they time you cut the cracks out, it would be too thin. They suggested just using as is, especially being on the rear.
I did find the axle seals. Here is the NAPA number if it helps anyone. Comes with the seal and both gaskets.
FORD PART: B4TZ-1001-A is the gasket only. (thanks to numberdummy posted in another thread)
NAPA 23870 comes with both gaskets and the seal. Might help someone in the future. Thanks.
Troy Bauer
Jan 17, 2018 02:14 AM
jkg234
Large Truck
Dec 20, 2016 06:58 PM
Shopteach
Large Truck
Sep 13, 2016 11:22 AM
jdubsweb
Feb 29, 2016 07:28 PM
willystyle21
1978 - 1996 Big Bronco
Jun 30, 2004 07:54 PM
