richsapp
Old Feb 13, 2018 | 05:46 PM
richsapp's Avatar
richsapp
richsapp
i have a 2003 f250 superduty and recently while pulling a load of hey it went limp wouldnt pull . felt as if transmission was stuck in 3rd gear light flashes on tow haul and jerks when you shift. made it home and turn of truck no when you turn key it goes thru the cycles but wont spin over .got 3 codes a p0528,p0603,p1000 no engine light . i can jump out the selonoid and engine spins over and will crank like this if key is own . any ideas what may be my problem?
Old Feb 14, 2018 | 02:45 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
What are you reading codes with? Seems like minimum you should see P0700 for the transmission since the T/H light was flashing, and since none of the other three you posted are related to the transmission I don't think you're getting everything.
P0528, you might have munched the fan clutch wires, no telling what that shorting out could do. You're going to have to look through the fan to see the wires in the second picture, to get to the view in the picture you have to drain off your coolant and remove the fan shroud.
Old Feb 14, 2018 | 05:24 PM
richsapp's Avatar
richsapp
wont crank in georgia
I am using a Innova diagnostic tool for obd2 codes . Iwill look in to thje fan clutch wiring and check for shorts.
SilentWeld
Mar 12, 2024 09:22 PM
Dp616
Jan 20, 2019 01:09 AM
tarzanmonkeyman
May 11, 2017 07:43 PM
Chris56ford
31
Jun 26, 2014 07:06 AM
Erik727
Feb 18, 2011 09:18 PM
