I have a 1995. 5.0 F-150. I left it sit for about a year when it blew the center out of a spark plug. Apparently, in spite of the folder full of maintenance receipts from the previous owner, he had never changed the plugs. Anyway, I recently got it back on the road with 8 new plugs but it is not shifting properly any more. It revs higher than normal at idle, and will not shift until over 4500 rpm (I can force a shift if I feather the throttle around 3500). If I am on the highway running around 100 kpg (60 mph), the truck is revving over 3000. If I shift it into neutral at that speed, the engine speed only drops to about 2200. If I leave the truck in neutral, and bring it to a stop, the rpms don't drop to idle speed (less than 1000) until I have come to a stop. Gas mileage is obviously brutal. Some research leads me to believe the TPS could be at fault here. I would be interested to hear any thoughts on this. Thanks
Given the symptoms I would lean towards a bad TPS. Before spending money on parts run the Key On Engine Off (KOEO) tests and Stored Code (aka CM) display. See what is there first.
I can 2nd the opinion of not buying anything but a real Ford replacement TPS if it comes to it. I chased what we thought was a e40d problem for weeks until we put in a fORD tps.
