'48 grille
Thanks for the encouraging words on the F4. It's been a challenging build and it's not even my truck! I've been restoring it for a friend. To answer some of your questions:
ChristiansenP: The grille was included with the stack of parts I was given. It was pitted badly on the back side and rusted through (small hole) between the left side of the grille bars and headlight hole. The hole was repaired and the body guy worked his magic smoothing out the pits on the front.
Jafo56: you have a keen eye. Yes, the grille and rims are the same color. I had the rims powder coated a couple of years ago and asked the painter to match the color for the grille.
EAK69: thank you for the picture. Definitely helps.
rustybits: if you have other pictures I'd like to see them too. I'll message you with my email.
Here's the story on pinstripes: https://www.ford-trucks.com/forums/1...ml#post1234340
The ones I've seen, the red stripes were on the recessed part of each bar. The first picture above looks wrong, the second looks closer but still on the faces of the bars.
As others have mentioned, the 48 grilles were painted tan (all references I've seen are Tucson Tan) with the red stripes similar to the 2nd pic from rustybits. Ross is correct regarding the placement, to my experience.
Hivolt, you have a handsome truck that shows some great work. Well done!
wow, so now I'm really confused on the grille. I've seen pictures of these trucks with the tan grille but most I've seen had silver grilles. Here are a couple of pictures of the F4 I've been working on in "as found" condition. The picture quality is bad but it appears to have a silver grille; of course I can't make out any stripes. Three other people 'worked' on this truck before I started so I'm not really sure what it's original condition was. The grille had already been sanded and shot with yellow sealer when I got it.
So what would you guys do? Should I leave the grille as it is now, or should I put the red pin stripe?
