E-350 huge parasitic draw, can't find it
Old 02-13-2018, 09:14 AM
Ian F's Avatar
Ian F
Ian F is offline
Originally Posted by wirelessengineer
Yep. Painful, but it's the next step.
Electrical problems are often like peeling an onion - one layer at a time.
Indeed. It can be made even more fun when you're working on a 20+ year old truck a previous owner has futzed with.
My van has a really bad draw right now that absolutely killed the batteries. After I get it running, the first step will be to rip out everything the PO did: stereo system, aftermarket alarm, etc. and start over. Plus, my van is a conversion and a diesel, so I have various conversion bits as well as dual batteries.
Thanks to Jeff for the link to the current clamp meter. I've had a heck of a time finding one that will measure DC current. So far all of the ones I have found in local stores specifically state they don't meter DC current, only AC.
Old 02-13-2018, 12:16 PM
Billy D. Scott's Avatar
Billy D. Scott
Billy D. Scott is offline
Originally Posted by jimbomitch
Power distribution box in the engine compartment? There's also relays in that. I'm wondering if it could be a stuck relay?
Correct. There's the power distribution box under the brake master cylinder (kind of a PITA to pull those fuses). Yeah, I also pulled each relay one by one, and no dice. There's also a sub panel type fuse box by the steering column. I initially checked voltage across the contacts on top of each fuse, but my meter can't read millivolts reliably so that didn't work out. That's why I started pulling fuses.
Old 02-13-2018, 12:19 PM
Billy D. Scott
Originally Posted by jeffreyclay
I can understand your frustration. Are you aware that with an amp-clamp you can surround a bundle of wires at one time and read the total current flowing? If everything is supposed to be off and you read current, then you can start to separate wires and read individually. The wire color should tell you which circuit is creating the draw.
Gotcha. Thank you. I ordered the meter you mentioned earlier. Should be here in a couple days; I'll get back to it then. I needed a new meter anyway, and that thing looks pretty handy.
Old 02-13-2018, 09:15 PM
wirelessengineer's Avatar
wirelessengineer
wirelessengineer is offline
I see two possibilities here:
  1. You missed a fuse somewhere. (Being human and all, it is possible. Really! It is!)
  2. The problem is not in a fused circuit.
So, what electrical circuit in a vehicle is not fused?
Starter, and starter solenoid.
Can anyone think of any others?
Wouldn't hurt to look there, anyway.
Old 02-14-2018, 06:17 AM
vettex2's Avatar
vettex2
vettex2 is offline
I don't know about on his year of van but it is on my '04
I had the fuse pop on my van.
I checked the wires at the starter and that led me to my manual and found the correct fuse to replace.
It was the first time I had seen that.
Old 02-15-2018, 03:16 PM
Billy D. Scott
I wanted to return to close this out. I found the draw. It's the solenoid. Really confusing, but it should be easy enough to replace the starter.
Thanks everyone for your posts. And thanks jeffreyclay for the tip on the meter; it's a great unit. It has everything I want and nothing I don't, and it's compact as well. Happy with it so far.
The following users liked this post:
Old 02-15-2018, 06:02 PM
wirelessengineer
Heh. Told ya ta look there!
Great that you got it solved, and thank you for posting back to let us know.
Old 02-16-2018, 09:32 AM
vettex2's Avatar
vettex2
vettex2 is offline
Good.........
pyroracing85
1983 - 2012 Ranger & B-Series
10-14-2016 06:48 PM
Bubba Jones
1978 - 1996 Big Bronco
09-17-2012 12:25 PM
norlandh
1997 - 2003 F150
08-27-2010 05:56 PM
BENG0924
1999 to 2016 Super Duty
01-22-2008 01:32 PM
bub3788
1997 - 2003 F150
02-13-2003 01:08 AM
Quick Reply: E-350 huge parasitic draw, can't find it
