98 F150 4.2L P0171 code
Have 4,2L with 125,000 miles. Check engine light is on with a P0171 code. When I first scanned the OBD2 there was two codes P0171 and P0174 codes. Changed spark plugs and wires along with a ETC sensor. Cleared codes and drove it few miles, light came back on and P0171 came up. System too Lean. I have great idle, no coolant loss. MPG has gone down. After the truck warms up I do hear a "ticking sound" could this be a intake manifold gasket? Or should i look at the EGR system?
Sounds exactly like what I had going on. I replaced the o2 sensors, intake manifold gasket and cleaned the MAF. It was the intake manifold gasket that solved my issue, the o2 sensors and MAF were just because I already had the truck apart.
You need something to read codes and show deeper information, it helps a lot. I have been using my sct x4 tuner to do everything plus custom tune it.
Nimrod.sixty9
09-25-2011 01:42 PM
