AC clutch kicking on and off
My 99 ranger is running great,,,no codes,,,no check engine light,,,but when running idle my AC clutch is kicking on and off with blower or heat or AC OFF...is this a issue or normal operation with blower and control off ?? It kicks on and off very quick,,,have not tried turning heat or AC on to see if it quits !!!Just need pointed in right trouble shoot direction if needed,,,is air gap to wide ??? just not a expert like Pawpaw LOl
The blower motor is "ON" any time the function selector switch is not in the OFF position.
A/C Compressor operation is enabled any time the function selector switch is not in the OFF, VENT, or HEAT positions.
To determine if you have a problem or not, you first have to determine if the function selector switch is in one of the positions where the compressor is supposed to be operating. If it is, then you have a problem with how it's operating when it is supposed to be operating (most probable). If it's short-cycling when the function selector is in a position where is shouldn't be operating, you have a different problem (or set of problems).
The most common reason for an A/C compressor clutch to short-cycle when it's supposed to be operating is due to an insufficient refrigerant charge, usually due to a leak. The less common reason for short-cycling involves a high-side restriction or overcharge conditions.
You need to first classify the the symptom under the conditions it occurs, then act accordingly.
Yes, your compressor will cycle on and off whenever the selector switch is in any position other than "OFF". The compressor is turned on and off by way of the refrigerant pressure switch. If it is running when in the "OFF" position, your system may be low on refrigerant, the pressure switch is bad or has a faulty connection..
ok thanks i will check into it more when the weather gets a little warmer,,,i have not had the system charged since i have had the truck,,,,my guess is a leak and low on refrigerant ,,, will let everyone know what i find when it warms up a little,,,just a little chilly and rainy right now
The compressor is short cycling in cold temps
I only drive the truck a couple of times a week if that ( short trips ),,,i will double check it next time i drive it,,,i am almost sure it is low on refrigerant and my neighbor has the gauges to check it,,,will post and let everyone know what i find soon,,,,just been to busy to mess with it right now,,,i have only used the AC once since i have had the truck,,,it blew cold air but not ice cold then and that was over a year ago,,,my money is it is low on refrigerant,,,,will hook gauges up when i have more free time
OK my mistake,,,I did have the heater on in defrost mode. I turned the control to off and drove a few miles to store and no clutch kicking .Drove home and left truck running with heater to feet and vents and clutch kicks on and off every 7 seconds !!!! It was 61 degrees out and was a steady 7 second on off,,,is this normal or is it probally just low on refrigerant ???? Sorry thought it was off in early post and it was in first position passed off
