Sponsored by: Real Truck
Homemade Traction Bars
Old Feb 9, 2018 | 08:15 PM
Obs7.3Powerstroker's Avatar
Obs7.3Powerstroker
So I’m fabricating my own traction bars. Was wondering if anyone else has made some up too. I have read you want make them the same angle as your drive shaft. Anyone else heard anything like that?
Old Feb 10, 2018 | 04:55 AM
Chuck's First Ford's Avatar
Chuck's First Ford
to what point??
traction bars are to prevent spring rap... SD using 3,4 springs.. should not rap
aka the rotation of the differential..
Old Feb 10, 2018 | 09:55 AM
Obs7.3Powerstroker
I attached a camera to my frame and video taped my spring. Definitely have some pretty bad rap.
Old Feb 10, 2018 | 11:39 AM
SuperDutyScaler's Avatar
SuperDutyScaler
Ford's dont wrap?, ever drive your truck on sand or snow? It makes tracks like a bulldozer....little ripples as the rear is tweaking away
Old Feb 10, 2018 | 12:06 PM
Obs7.3Powerstroker
MY truck also has a 4” lifting block, which I’m told will increase wrap. In the video I made my Spring was making an S shape. When you left off the gas you can feel the spring clunk back into its normal shape.
Old Feb 10, 2018 | 12:54 PM
speakerfritz's Avatar
speakerfritz
traction bars are a plus on a superduty....it definitely makes a difference.
becareful how they bolt to the frame....while some preload is good....too much negative preload is not
Old Feb 10, 2018 | 01:25 PM
don123's Avatar
don123
Can you post a video of this?
Old Feb 10, 2018 | 06:10 PM
projectnitemare's Avatar
projectnitemare
The true answer, it depends. Are they solid mount or with a shackle? Adding any lift block will make axle wrap worse since there is more leverage against the springs. Unless you know what you're doing best bet is to mimic a commercially made set. Most common problem usually is use of solid mounts and something breaks since the suspension will eventually bind.
Old Feb 10, 2018 | 08:44 PM
Obs7.3Powerstroker
I am copying longhorn fab traction bars. Using third links from a tractor three point hitch for the rod ends and 1 1/2 pipe for the bars.
Old Feb 11, 2018 | 05:47 AM
projectnitemare
That's where you are going wrong. I use dom for anything suspension related. Sure, structural steel pipe is strong; that debate has raged on for ages. I have yet to find threaded bungs for pipe. If you're going to use pipe, you need sch 80 for a 6 foot bar like you are looking to make. For a traction bar using pipe wouldn't be a crime but using those garage tractor links is. Use real rod ends, not the hitch links, they don't last.
Old Feb 11, 2018 | 09:31 PM
Obs7.3Powerstroker
what is dom?
Old Feb 11, 2018 | 10:23 PM
BioBurner's Avatar
BioBurner
what is dom?
D.O.M.
Drawn Over Mandrel
It's a type of tube that doesn't have a weld seam like pipe does. Much stronger for the weight than pipe.
Old Feb 14, 2018 | 12:35 PM
Obs7.3Powerstroker
Does anybody know how much the bars should be pre-torqued?
Old Feb 14, 2018 | 12:43 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Since you're wanting to use heim joints (the ends off a top link for a tractor 3-point hitch) for your ends, what are you going to install that will allow some "give"?
Old Feb 15, 2018 | 01:49 PM
Obs7.3Powerstroker
Not the way I have it set up right now. How would you make it so it has some give?
