Windshield washer fluid
Old Feb 8, 2018 | 05:08 PM
Paul Yager's Avatar
Paul Yager
Brand new 2018 f250 ccsb. After driving and using washer fluid at around 1100kms, low washer fluid indicator came on.
I put in about 3/4 big of fluid and light went off. About an hour later of driving, light came back on. I hadn't used much if any fluid.
I then added the remaing fluid from jug and indicator went out.
I haven't driven since and don't see any liquid under the truck that is parked in my shop.
any idea? Anyone know how much the washer container holds or if there are any known issues with these tanks leaking or floats inside misreading levels?
Old Feb 8, 2018 | 05:22 PM
mhoefer's Avatar
mhoefer
It holds a total of about 1 gallon. (4 litres) I can usually get a hole container in if the low light is on.
Old Feb 8, 2018 | 06:57 PM
RCR70ss's Avatar
RCR70ss
Just add Def?
Old Feb 8, 2018 | 07:04 PM
KCJackson1's Avatar
KCJackson1
It may also depend on what kind of washer fluid you use. The fluids that claim to have Rain-X type ingredients ("Beads/repels water!") have been known to coat the sensor to the point it no longer realizes it's wet and throws a false low fluid warning, even when the reservoir is well above empty. Usually that will take more than one refill to cause such buildup on the sensor, and it doesn't necessarily happen to all vehicles, but it's something to consider.
Old Feb 8, 2018 | 07:10 PM
cficare's Avatar
cficare
We've got a sensor telling us when the washer fluid is low? Cool!
Old Feb 8, 2018 | 07:12 PM
RCR70ss's Avatar
RCR70ss
yes...you have about 3 more sprays before ya don't have no more not really pracital
Old Feb 8, 2018 | 07:19 PM
cficare's Avatar
cficare
Couldn't find any mention of such an indicator in my 2017 OM. Is this something new for 2018 MY?
Old Feb 8, 2018 | 07:26 PM
RCR70ss's Avatar
RCR70ss
not new.....use it up. just have more close...its a big windshield to clean
Old Feb 9, 2018 | 12:21 AM
f350ktm's Avatar
f350ktm
+1, news to me also.
Old Feb 9, 2018 | 03:21 PM
mhoefer's Avatar
mhoefer
I also wish I had sprayers for the headlights, driving lights, and rear cameras. Same size washer container as every other vehicle I have ever had.
Mike
Old Feb 11, 2018 | 09:05 AM
brock961's Avatar
brock961
My 2017 recently started doing the same thing. I fill it and in a short period of time - a few days to yesterday 8 hours - my fluid is empty. It seems to hold about 3/4 of a gallon, and there is no way I am using that much.
Guess it is time to take it in.
Old Feb 17, 2018 | 11:26 AM
brock961's Avatar
brock961
Fixed
Turned out that the sprayer for the front camera had an issue and was allowing the fluid to continue to drain out after using it. Apparently there is some sort of check valve in it to prevent this which was not working. The front sprayer has been replaced and all is good.
Old Feb 17, 2018 | 12:15 PM
Paul Yager's Avatar
Paul Yager
thanks for this.... I'll see if that was what the issue was. At this point it doesn' seem to be losing fluid anymore. Maybe just a one time thing.
Old Feb 17, 2018 | 01:50 PM
brock961's Avatar
brock961
Mine would leak a while and then stop for a while. Typically it took 2-3 days to empty the fluid, but one day it was as short as 6 hours.
Old Feb 17, 2018 | 06:27 PM
roadpilot's Avatar
roadpilot
Seems like the washer fluid in my '17 empties out very quickly - far more quickly than I expected.
