Does death wobble “go away”?
Old Feb 7, 2018 | 01:24 PM
Cabindweller's Avatar
Cabindweller
I had an experience on the highway today that can only be explained as death wobble. I got to the office, ran in for a conference call and then headed back out on the highway to test and go straight to my dealership. On the test trip, I experienced none of the symptoms that I had just dealt with an hour before hand. The truck seems to be performing as it should? I did not take it to the dealership.
We had a big snow this morning and I was in 4x4. Right before the DW started I shifted into 2WD while on a curved onramp, traveling about 40mph. Could it have just been an issue with a hub not disengaging properly?
Can DW be intermittent or does this just sound like a fluke?
Old Feb 7, 2018 | 01:43 PM
HRTKD's Avatar
HRTKD
My experience with the wobble was also on a curved ramp. The expansion joints caused it.
What setting do you have your Rancho front shocks on?
Old Feb 7, 2018 | 02:19 PM
Cabindweller
5 currently.
Old Feb 7, 2018 | 02:54 PM
HRTKD's Avatar
HRTKD
Mine are on 4 and I think that made the wobble more pronounced.
Old Feb 7, 2018 | 03:10 PM
Tranz zam's Avatar
Tranz zam
Death wobble doesn't go away. It usually gets worse over time.
Old Feb 7, 2018 | 05:19 PM
Cabindweller
I just drove home, 40 miles on the highway at speeds between 55-70mph. No issues whatsoever. The truck seemed completely normal again. Would DW be so intermittent that I could go for distances like this without seeing any symptoms? Or is it more of a case that once it shows up, the symptoms are pretty consistent?
Just trying to figure out how concerned to be. I'll be towing my fifth wheel to the Smoky Mountains next month and would love to have a trouble free trip.
Old Feb 7, 2018 | 05:59 PM
falconetti's Avatar
falconetti
any snow packed in the wheels? or mud? that will cause a bad shimmy for sure.
Old Feb 7, 2018 | 06:11 PM
Cabindweller
It’s interesting that you would ask this... When I walked out to get in my truck, I noticed that it looked like the guy plowing the lot pushed snow right up against my truck. The front driver’s side wheel was almost completely covered up. I was annoyed. Plus, I had just driven for an hour in heavy snow covered roads and then parked the truck for a few hours. I can’t swear that snow was “packed” in the wheels but I wondered if that could be it as well.
Old Feb 7, 2018 | 07:47 PM
Snowman 8's Avatar
Snowman 8
Mine went away after installing a 2” Fabtech level with 4 new Skyjacker shocks, a Skyjacker steering stabilizer, new tires and wheels and an alignment. When they threw my truck on the alignment rack it was initially out of alignment, I cant find my spec sheet anymore but it was toe’d out and the caster was at about 1.3 and 1.4 degrees. Now they have it set around 1.6 -1.7 and the toe in is set correctly.
Old Feb 8, 2018 | 07:22 AM
Cabindweller
40 more highway miles into work this morning... Still no issues or signs of DW.
Old Feb 8, 2018 | 07:26 AM
Snowman 8's Avatar
Snowman 8
I don’t want to be the bad guy but once it starts it won’t fix itself... It will come back and each time it comes back it will be worse than the last time. My 17 and my 11 did it.
Old Feb 8, 2018 | 07:38 AM
CBEllis's Avatar
CBEllis
Snowman’s right. It usually takes a certain set of circumstances to make it wobble, the road, the tilt of the wheel, the influence of the balance of each one, etc. All of these outside influences have to hit the truck just right, which will only happen on specific occasions. I’d check alignment 1st, balance 2nd, then move on to joints, sway bar bushings, etc. Hate it for you - that uncertainty sucks and, if someone’s never experienced it, it can be very unnerving.
Old Feb 8, 2018 | 07:52 AM
Cabindweller
Thanks all. I’m going to head to the dealership tomorrow morning.
Old Feb 8, 2018 | 11:48 AM
Painted Horse's Avatar
Painted Horse
my wobble was almost always triggered by left hand radius turns in the 40-55 mph range, when id hit a rough expansion joint on the curve.
Old Feb 9, 2018 | 03:50 PM
Kenv's Avatar
Kenv
CBEllis....WHY would he check all those things when it's already been identified that the death wobble is fixed with just the sway bar. It is NOT tires...alignment or any of the other things you mentioned. A new Ford swaybar fixes it....at least the ones I have ridden in after the fix and what I've read on here. Just trying to simplify it for the one asking.
