UVCH Ford part #
Old Feb 7, 2018 | 12:43 PM
afonda's Avatar
afonda
UVCH Ford part #
Anyone have the "new" ford part # for the UVCH? I'm being told it is better due to the larger diameter wire... and was redesigned to be more reliable.
or is the international / alliant part that is better?
Old Feb 7, 2018 | 12:44 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
UVCH
Under Valve Cover Harness 99-03 (F81Z9D930AB)
Gasket
http://www.riffraffdiesel.com/valve-cover-gasket-99-03/
Old Feb 7, 2018 | 02:50 PM
afonda's Avatar
afonda
Just added to my wish list along with the pigtail. Are these the newer better ones? I was told the wires increased to a thicker gauge...
Old Feb 7, 2018 | 05:11 PM
Sous's Avatar
Sous
FTE Emeritus
I cannot say for sure, but it is a safe bet that if there are newer/updated versions that RiffRaff is selling them. He is pretty quick to reply if you wanted to ask him and make sure. If you do, post up the response for others to read for years to come.
Old Feb 7, 2018 | 06:11 PM
duck fan's Avatar
duck fan
Because racetruck
Yes, the ones Riffraff sell are the most updated. I just installed some one a friends truck about 3 weeks ago. Nice and tight unlike the originals.
Old Feb 8, 2018 | 08:26 AM
ExPACamper's Avatar
ExPACamper
When you pull the old ones off, please get a comparison pic to show the thicker wire?
Our trucks LOVE new UVCH
Old Feb 8, 2018 | 09:55 AM
afonda's Avatar
afonda
Makes you wonder...
I got new injectors 14 months ago cuz the truck was running so bad... truck ran better.. but now I'm 2nd guessing that it may have just been the uvch.
Old Feb 8, 2018 | 11:05 AM
ExPACamper's Avatar
ExPACamper
I may have had just one stuck injector. But...now I KNOW the injectors are fresh and ready to last a long time- probably for much, if not all of the time I have her.
There is confidence and comfort in that knowledge. Rest easy with your choices
Old Mar 2, 2018 | 08:51 PM
afonda's Avatar
afonda
As requested.....
Old Mar 2, 2018 | 09:44 PM
Colorado Horseman's Avatar
Colorado Horseman
Can anyone justify the two piece design that does nothing that I can see but increase the possible failure points?
Poor engineering from the beginning. Continues to be poor in current iteration.
Old Mar 2, 2018 | 10:06 PM
Sous's Avatar
Sous
FTE Emeritus
Supposedly the newer 2 piece UVCH's are improved and no longer require the 50 cent mod, but I am not 100% on that.
In addition, there was a post a few weeks back with detailed information on the OEM 2 piece vs Dorman 1 piece UVCH. It was determined that the OEM had thicker wire and larger pins for better continuity. I cannot remember who it was that posted the information.
Old Mar 2, 2018 | 11:40 PM
afonda's Avatar
afonda
Look close a t the spacing in the connectors. Old one has large gaps...
I view these things like spark plugs... gotta change them sooner or later....
Old Mar 2, 2018 | 11:44 PM
brandon_oma#692's Avatar
brandon_oma#692
Can someone explain what you mean by 2 piece please? I'm lost.
heavier wires sound good to me
Old Mar 3, 2018 | 07:46 AM
Walleye Hunter's Avatar
Walleye Hunter
Two piece means that the wires on the inside of the VC have a connector on them and there are two plugs on the VC gasket, one for the main wiring harness then one for the UVCH. One piece has the UVCH permanently attached to the VC gasket, eliminating the possibility of it falling apart under there. And, IIRC there was a statement to the effect that Dorman used aluminum wire instead of copper.
Old Mar 3, 2018 | 08:29 AM
Sous's Avatar
Sous
FTE Emeritus
The Dorman 1 piece is pictured below. You can see where the wires that go to the injectors and GP's are permanently attached to the connector, which goes under the edge of the valve cover and out to the OEM harness. The 2 piece by Ford is just that. The gasket is 1 part, then the wires under the cover is another part.
Again, the 2 piece is a more complex design, but is said to be much better in quality of materials and connections. The original design would allow for the connectors to slip out a bit causing problems with the injectors, but the new design has since eliminated that issue.
