Died while driving...
Old Feb 6, 2018 | 03:20 PM
2fifty's Avatar
2fifty
so I was driving my 7.3 to school this morning and it didn’t give me any **** or anything and I got to school without an isssue but when I went to drive home, about 2 minutes into the drive it started running super rough then died.
It started red again and died again. I got it to start again and it actually stayed running but I had my foot to the floor and it cranked for a while. I don’t think this would be a problem but I did install 2 new batteries last night. Can someone please help diagnose this? I will give as much info as you guys need but I don’t know what to do!
Old Feb 6, 2018 | 03:26 PM
farmert's Avatar
farmert
Do you have a check engine light on? Check the harness plugs to the injectors/glow plugs for melting.
Old Feb 6, 2018 | 03:59 PM
z31freakify's Avatar
z31freakify
Hows the oil level?
Old Feb 6, 2018 | 10:27 PM
2fifty's Avatar
2fifty
Well I just had new glow plugs put in a month ago but she leaks a lot of oil. Could that be the problem?? I’ll check her tomorrow morning to see how the level is. I should also add this issue was after sitting for 7 hours in like 10 degrees.
After starting it for for the third time it finally ran right and it ran normal for the remainder of the drive home.
no check engine light ever came up
Old Feb 7, 2018 | 06:27 AM
DIYMechanic's Avatar
DIYMechanic
Fuel Gelled up? Do you run any fuel additive? I've never had it happen to mine, but a buddy has had his 6.0 gel up twice on him in as many winters.
Old Feb 7, 2018 | 09:04 AM
2fifty's Avatar
2fifty
Wasn't gelled and fuel gets treated. She was quite low on oil as she leaked more than I thought.... it didn't act up this morning and I'm just hoping that was a one time problem related to the oil level. I've since filled the oil back to safe levels. Still unsure if oil level caused the problem.
Sometimes it pays to maintain your vehicles, new concept to me I guess
Old Feb 7, 2018 | 09:09 AM
knottyrope's Avatar
knottyrope
run low on oil and injectors wont fire anymore
ho low were you?
Old Feb 7, 2018 | 09:11 AM
BuddyBarnes's Avatar
BuddyBarnes
Where is the oil leak ?
Old Feb 7, 2018 | 08:55 PM
2fifty's Avatar
2fifty
It didn’t even show on the dipstick.... I know I should’ve checked earlier!!! I messed up.
It leaks out out the drain plug cuz the dang PO stripped that sucker good
Old Feb 7, 2018 | 09:15 PM
z31freakify
Normally the bolt strips out before the threads on the pan do just a thought, might get away with buying a new plug.
Old Feb 7, 2018 | 11:01 PM
2fifty's Avatar
2fifty
Already tried that, pans stripped
Old Feb 7, 2018 | 11:16 PM
farmert's Avatar
farmert
They make oversized, self tapping drain plugs.
Old Feb 10, 2018 | 10:22 AM
jimzpsd's Avatar
jimzpsd
Sounds as though it was a low oil issue, but how old is the CPS? Most OBS owners carry a spare just in case, its a ten minute fix. Your symptoms are identical to a failing CPS.
https://www.ebay.com/itm/Ford-F250-7...ZYfRG0&vxp=mtr
FUJINAMI1293
27
Jan 21, 2013 10:58 PM
350long
Nov 8, 2010 07:40 PM
RRranch
Dec 10, 2009 03:41 PM
Byrddog
Sep 3, 2008 06:14 AM
Dave7.3
54
Jan 10, 2007 10:47 PM
