Vacuum leaks, low fuel pressure?
96 e150 5.8L
Fuel pressure at idle is at 30psi. right at the low point.
Can loss of vacuum created by removing the dipstick/oil cap be enough to stall out the engine?
I've been having a nagging p0171 and p0174 code. Most of the time, idle is smooth as butter but occasionally it get a little rough.
Left me stranded twice already and trying to figure out alternative before I have to drop the tank. Changed fuel filter already and maybe think that there is a lot of sediment in the tank or the pump is plugged, failing?
Also, can a faulty EGR or IAC cause these codes and stall out.
TIA for any input.
btw, i did a smoke test which showed no leaks. I watched the mechanic work and he did a thorough job looking everywhere.
Also I have a new MAF, fuel regulator and pcv valve,grommets.
TIA for any input.
It was warm. Had just pulled into the shop after driving for about 1 hour. They did the fuel test about 30 minutes after I pulled in.
Thomas Boersma
03-24-2023 07:46 PM
Mvuu
26
10-10-2018 09:32 AM
powerstroker100
03-19-2014 08:19 PM
dwayne21
07-04-2010 05:45 AM
