Front Hitch Mount for 1990 E350
Old Feb 2, 2018 | 05:16 PM
B190 Space Team's Avatar
B190 Space Team
I am looking for a front hitch mount for a 1990 E350. The normal Reese and Curt hitches seem to only be for the 4th Generation Econoline's and I have a 3rd Generation that I'd like to mount the hitch receiver onto.
Is the frame/bolt pattern that different between generations? Will a front hitch receiver for an F Series truck from that same year fit?
If anyone has a lead on a front hitch that will fit my 1990 E350, I'd much appreciate getting pointed in the right direction.
Sincerely,
Noah
1990 Airstream B190 on a Ford E350 chasis
Old Feb 3, 2018 | 06:54 AM
Rick1025's Avatar
Rick1025
Get the universal type. The tube telescopes to whatever width you need. I remove the front bumper and get access to the inside of the frame tube to bolt it through the frame. A little more work,but it makes a solid mount. I picked mine up on Craigs list. I have them on all 3 of my E 350's and an 1 1/4 version on the front of my suburban.Surf fisherman all use them. I use them to move trailers into tight spaces.Also works wonders for putting a boat into and out of the water. Keeps the rear drive wheels on dry ramp.
Old Feb 3, 2018 | 05:18 PM
B190 Space Team
Can you send me a link to what you have in mind? I can't seem to find any universal or adjustable front mounted hitches. Thanks for your reply!
Old Feb 5, 2018 | 07:31 AM
Rick1025's Avatar
Rick1025
Google "multi fit receiver hitch" or Universal receiver hitch"
Old Feb 5, 2018 | 12:59 PM
Teutonics's Avatar
Teutonics
I haven't done it (yet), but I've read that the frame spacing is the same front and back, so if you're willing to drill your own holes you can use one that's made for the back. I purchased one off CL for $25 to try it, but haven't gotten around to it yet (waiting on warmer weather... and available time). You may want to do some investigation to confirm before going that route.
Old Feb 5, 2018 | 01:28 PM
kennyfzj80's Avatar
kennyfzj80
Sincerely,
Noah
What do you plan to use the front receiver for? just curious
bcorg
17
Jun 30, 2025 06:49 PM
gijim2k1
2004 - 2008 F150
Apr 15, 2012 06:04 PM
jgavac
Jan 20, 2012 08:00 AM
ejstave
Aug 6, 2007 03:39 PM
rakent
Apr 29, 2004 02:18 PM
