Misfire
Old Feb 4, 2018 | 11:22 PM
kr98664's Avatar
kr98664
Originally Posted by Kenneth Spivey
Did a compression test all cylinders where within 5 to 10 pnds of each other all being 140 to 150.
I'm lost. You've got a valve not opening. Wouldn't that have affected the compression test? Or am I in left field again?
Old Feb 4, 2018 | 11:48 PM
Franklin2's Avatar
Franklin2
Sounds like his problem is a random type thing that may have gotten worse after he did the compression test. Sounds like he is all over it now.
Old Feb 5, 2018 | 11:37 AM
FuzzFace2's Avatar
FuzzFace2
if the exhaust valve is not opening it will pull air in but not let it out. It has fuel in it and it expands but with no place to go once the intake valve opens you get it coming out the intake track.
You would also get a good compression reading.
If you pull the side lifter cover you should be able to see if the outside of the lifter is moving or not then you can check the inside part if it is moving with everything back together.
Dave - - - -
Old Feb 6, 2018 | 07:44 AM
Kenneth Spivey's Avatar
Kenneth Spivey
Ok so here's an update. Had to order the parts cause no one around here has them in stock. But I did confirm this was my only issue left. I took some thin metal and made a shim. Stuck it between the rocker and valve and backfiring and missing was gone also the awful sqeak to. So I do want to thank everyone who helped me out.
wfon
Oct 8, 2014 07:45 PM
IlovemyFord37091
Sep 26, 2014 12:08 AM
Blackwaterforge
Aug 31, 2009 03:26 PM
motobub
Apr 9, 2003 03:52 PM
TKONO
Jun 20, 2002 10:47 PM
