1988 300inline6
Old Feb 4, 2018 | 05:14 PM
Jacob Brueckner's Avatar
Jacob Brueckner
1988 300inline6
Well I'm hving a acceleration problem. Truck idles great. Sometimes when driving I will give throttle and then the engine light comes on then goes off when I let up on gas or press down. This happens when climbing hills and on the highway(speeds around 35 or higher. I'm thinking sensor. Engine coolent sensor, egr, o2, idk I'm clueless. This EEC_4 SYSTEM IS DRIVING ME NUTS
Old Feb 4, 2018 | 05:52 PM
rla2005's Avatar
rla2005
Quit guessing. All it will do is empty your wallet. The Check Engine Light means there is a stored code or codes. Run the Key On Engine Off (KOEO) tests and stored code (CM) display.
List the two digit codes by number and when they were displayed.
Old Feb 4, 2018 | 06:03 PM
88n94's Avatar
88n94
I assume you are talking about the RED colored "engine" light rather than the "check engine" light?
I think that is supposed to only come on with very low or no oil pressure or if the engine is overheated. Did you by chance look at the oil pressure gauge when the light was on?
Old Feb 4, 2018 | 07:09 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Why would you assume that he is talking about the engine warning light and not the check engine warning light?
Old Feb 4, 2018 | 07:22 PM
88n94's Avatar
88n94
Because he said engine light, not check engine light. I guess we will have to hear back from the OP.
Noahwilliams
Aug 25, 2015 04:02 PM
alopez2
Nov 29, 2004 06:54 PM
tHeCoS
1978 - 1996 Big Bronco
Dec 29, 2003 11:41 AM
Katzen
Jun 20, 2003 12:07 PM
Rodriguez
Jul 31, 1999 05:07 AM
