Hello everybody, I'm building a 79 F250 4x4 and will be installing a 429 from a Lincoln car. He's the problem I have a C6 trans I was going to use but figure now would be the time to put a overdrive in it. What overdrive trans would be my best option between a big block and a NP205 transfercase? Thanks
Would recommend gear vendors for same cost and bolt in.
I’ve been looking at the different possible options to get a overdrive set up in my ‘77 F150 4x4. I would have to agree with your comment of going the Gear Vendors overdrive route as well.
It’s the next major expense that my truck gets. I’m hoping this summer I can do it.
AOD never had a big block bell pattern stock. I believe you can get built ones with a custom bell but ur talking $$$. E4OD would require a standalone controller which would be around $500-600 with a harness. They are not awesome when stock but can be built to be very hefty. Diesel and Lightning guys put tons of power through them
