Seat Swap
Old Feb 3, 2018 | 02:40 PM
roxndirt64's Avatar
roxndirt64
Seat Swap
This might be beating a dead horse but Im gonna ask anyway. I have a 77' crew cab that I want to put seats in out of a 97' F350 crew cab. Ive read where the seat swap is pretty easy that you take the seat tracks off the 77 seat and mount on the 97 seats. Ok so the 97 40/20/40 seat has the large frame under it where both buckets and center seat/console are mounted. So is it easiest to mount the 77 slides to the framework or is it better to remove the frame and mount everything independently? Im only talking front seat right now. Like to know what other people have done thanks.
Old Feb 8, 2018 | 09:55 PM
Overbored's Avatar
Overbored
4wd Low
I ended up abandoning the 97 mounting brackets, and used the stock 79 front seat guides and mounts. I used 3/4" x 1 1/2" .120" tubing across the guides and mounted the seats to this. It defeats the individual adjustability feature, but it places the seats much lower in the truck (similar to factory seat height). I had to do some trimming on the center seat/console to get it to match the height of the buckets, but so far, it is working fine.
PS: I needed to tilt the seats back, using about 3/4" spacers (which were welded onto the front rectangular tubing) to make them comfortable for me, I'm 6'2".
Old Feb 9, 2018 | 07:05 AM
CelticOne's Avatar
CelticOne
Regular User
If I recall correctly, only up to '96 are a direct bold in with the original tracks.
Old Feb 9, 2018 | 07:57 AM
4x4slik's Avatar
4x4slik
F150 changed in 97, f250 and f350 changed in 98. So, a 97 F350 is still OBS.
Old Feb 10, 2018 | 04:14 PM
Overbored's Avatar
Overbored
4wd Low
The bench front seats up to 97 do work with the early tracks, the 40/20/40 seats are a little bit more complicated to retrofit
Old Feb 11, 2018 | 10:59 AM
CelticOne's Avatar
CelticOne
Regular User
Thanks for setting that straight, guys. That's what happens when you try to do things from a memory that isn't quite what it used to be!
whitey97
Jun 22, 2024 08:06 AM
squirrel64
Jul 7, 2012 03:39 PM
JustDriveTwo
Nov 14, 2011 06:13 AM
gonefishin10987
1997 - 2003 F150
Oct 25, 2008 11:45 AM
Kake
Nov 3, 2002 04:42 PM
