Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F600 Split Rim Problem Solved
Old May 5, 2018 | 01:03 PM
Dirtbag's Avatar
Dirtbag
Here's a picture of the 11.00x20 GOODYEAR radials and M35a2 wheels
Old May 5, 2018 | 01:31 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Disagree if you’d like, but there are more than two military wheels. I cite six in the thread I linked in the earlier discussion. Below it is again. Edit - also note the fact that specs on military wheels are not released for publication in civilian references until their classified status is removed. So there may be more than the six wheels I referenced above.
https://www.ford-trucks.com/forums/1...s-on-f600.html
The point is that measuring offset or backspace will help ensure that a set of wheels will work with the tires in a drw mounting. Stu
Old Jul 5, 2018 | 10:06 PM
Ed Libby's Avatar
Ed Libby
I've got a 77 Ford f600 duelly and I'm looking for ruins that would fit
I've got a 77 Ford f600 duelly and I'm looking for upgraded rims and i read you were selling a set off 6. If so how much you liking to get for them.
Old Jul 8, 2018 | 06:30 AM
ASE_Mechanic's Avatar
ASE_Mechanic
3rd Gear
Just want to say thank for this thread. I've been fighting the split-rim issue on my 64 F600 and came across this. Now, I didn't go with the military take-offs, but instead with a set of Accu-Ride steels. I will say that the part numbers on the lugs were a lifesaver, though. Thank you for that information!!!
As soon as the wheels come in and I get them mounted, I'll throw up some pics. :-)
Old Oct 16, 2018 | 11:29 AM
poppatello's Avatar
poppatello
any pictures yet?
Old Jul 23, 2019 | 05:24 PM
Cliffy carlock's Avatar
Cliffy carlock
Originally Posted by banjojelly
I have a 1964 F600 with the common for the year two piece widow maker rims. The tires were worn out and the rims were rusty, and while I do have a local tire shop that will work with split rims, I did not think the rims were in good enough condition to survive tires being changed on them. Plus, at 200 dollars a tire for 9.00 x 20 tires, It would be $1,200 for new tires plus the cost of mounting and tubes. Spending $1200 on tires to put on obsolete rims for a truck that is only worth $800 is economics that only our government could justify.
I did a lot of reading on this forum and others, as well as a lot of google searching and emailing sellers of wheels for measurements. This has been a year and a half process off and on for me. Lots of people have asked the question "How do I replace my two piece rims?" Most of the time, the answer is something along the lines of "There was another factory option of different style rims and you might get lucky to find some but no one knows where to get them so good luck." Or "An aftermarket company made some that would fit but they haven't made any in years and no one has any, but you might get lucky to find some but no one knows where to get them so good luck." Or sometimes "So-and-so company will make you custom $$$$$ rims for your $800 dollar truck." Or my personal favorite "Why in the _____ are you wanting to drive a 64 F600 on the road for anyway!?"
I couldn't accept any of these answers, and about a month ago I stumbled upon a cheap and 100 percent bolt on solution for all of us with the split rim problem. It seams that even after Ford stopped using the 6 on 8.75 bolt pattern, the military used them on equipment with Rockwell style axles for years. They did not use split rim, but rather the much better lock ring style rim. They we also stud piloted using a ball seat style lug nut as apposed to the F600 hub piloted rims. It also appears that the military is phasing out this style of wheel and rim and replacing them. You can find them all over ebay. I measured a set and found they would bolt on my truck perfectly. I also researched lug nuts and found a set that I was confident would convert my truck from hub pilot to stud pilot without converting wheel studs. I took a gamble and ordered 6 military rims with mounted tires that were guaranteed to be 90% tread or higher, for $85 a piece from an ebay seller who had hundreds, if not thousands, of them.
https://www.ebay.com/itm/173046524154?ul_noapp=true
I also ordered these lug nuts for the front
https://www.ryderfleetproducts.com/e...t-p-439-e5652r
And these for the rear
Inner https://www.ryderfleetproducts.com/e...t-p-439-e7897r
Outer https://www.ryderfleetproducts.com/e...r-p-439-e5977r
I have mounted all 6 on my truck and they fit perfect. The lug nuts for the front are made with an enlargement before the threads that will slide over the unthreaded portion of the front wheel studs.
I spent $600 plus shipping to do this conversion to my truck.
Hopefully for all of the other people with this same problem, this will be of some help.
Please tell me the contact to the dealer you got your wheels on Ebay. The link no longer works.
Thank you.
Old Nov 8, 2023 | 06:58 PM
SCFlareside's Avatar
SCFlareside
great thread, does anyone know what lug nuts these are? The link is broken….
lug nut link broken
Old Mar 21, 2025 | 12:32 PM
tauntingdk's Avatar
tauntingdk
1st Gear
hello I am in desperate need of something to do and it seems that all of these sites have closed is there anyway you could help find some updates sites thanks in advance
Old Mar 21, 2025 | 01:17 PM
85e150's Avatar
85e150
"Something to do...."???
Please clarify.
Also, you can do a search using the various terms here and see if you can find wheels for sale, if that's what you're after.
Old Mar 21, 2025 | 02:03 PM
banjojelly's Avatar
banjojelly
Trailering
I don't spend much time on here at all anymore. Got too tired of all the guys with old parts books not being able to look past them. That being said, I still get an email every couple months or so of people looking for links.
Can't help you on the wheels. Just search out military take offs and do some checking.
As for lug nuts and studs. I will just post the copy of my receipt from 2018. You should be able to use at least the part numbers from it. Hopefully that helps with anyone else wanting to track them down.
Qty Item Number Description Availability Unit Price Total Price
13 439 E5652R Single cap nut Stocking Item 1.31(ea) 17.03
13 439 E7897R Inner Cap Lug Nut Right Stocking Item 2.76(ea) 35.88
13 439 E5977R Nut outer Stocking Item 0.76(ea) 9.88
Order Subtotal 62.79
Promotional Discounts 0.00
Shipping Charges 7.95
Estimated Taxes 0.0
Order Total 70.74
Good luck.
Old Jun 24, 2025 | 07:02 PM
Phatboy Slicks's Avatar
Phatboy Slicks
2nd Gear
Info on truck
Estimated Taxes 0.0
Order Total 70.74
Good luck.
I was wondering if you happen to have the pictures that you did on the f600 build? I was on another forum and seen you built it with your class. I have been trying to figure out how to do this and your info you put on there is amazing. The pictures wasn’t loading and didn’t know if you happen to have them still? Would really like to build this with my family. Thanks
Old Jun 25, 2025 | 11:55 AM
Phatboy Slicks
2nd Gear
I know you sent me a private message on the tractor forum, could you private message me on here? I keep trying to message you back and i keep getting blocked for spam...
Hossrod
Sep 24, 2018 10:33 AM
Jake49
Jul 15, 2016 10:37 AM
L.TONY F350
34
Jul 4, 2012 12:19 AM
bgphotoo
1997 - 2003 F150
Jun 30, 2008 12:04 AM
