1996 F250 HD 5.8l help with fastener sizes
I have purchased a project truck through an Auction site. Initial goal was to see if I could get it to run. I did and in doing so I’ve discovered #8 cylinder has burnt piston. I’m going to attempt to replace piston and all gaskets involved. I’m close to pulling motor today and many problems I have encountered are hardware problems. Appears every time this truck had a problem the last owner lost bolts and used what he found in a bucket lol. Can someone lead me to a manual or site that will identify the original fastener size? Example: passenger side head where alternator bracket is mounted. What was the original size bolts, pitch and length. I have removed so much from motor and zip locked labeled bags for hardware that came off. Only problem is most is incorrect or missing. Any help would be much appreciated.
Jeff
Jeff
Is one side of the nut beveled like a lug nut? If so, it's an all metal top lock nut. It will start by hand for 2-3 threads but you will have to wrench it the rest of the way on.
Locking nut or not. These nuts are oval like as in forced on. I’m replacing the motor mounts and can carry one into local hardware store. I was ordering some fasteners and thought if anyone knew the correct size...I have some thread gauges for standard thread and none fit..Must be metric.
s.car
03-09-2018 08:19 PM
Tartersauce53
32
04-02-2017 08:29 PM
