1963 Econo-Pickup Parking/E-Brake Pic
I picked up a 1963 E Pickup and the parking/e-brake "lever" is only a stub sticking into the cab.
Can someone post a pic of what should be there?
Also a pic on the front of the engine hood in-between the latches, I currently have to empty holes.
Thanks in advance!
Thanks in advance!
The E-brake handle was a plastic part that broke because of time, and because folks put too much stress on it. Here is a link to someone making an aluminum replacement.
Buy 61 62 63 64 65 66 67 New Aluminum Econoline Parking Brake Handle motorcycle in Las Vegas, Nevada, US, for US $40.00
There should be a small hole near the top of your shaft where the pin holds the handle on.
The Mustang and Falcon handle are the same as the Econoline, except the writing is upside down.
https://www.cjponyparts.com/scott-dr...5-1966/p/PBH3/
This one says it is for the Econoline, but looks upside down.
Parking Brake Release Handle | Dennis Carpenter Ford Restoration Parts
The trick to keeping a plastic handle around for years is to grip the parking brake handle with the vertical shaft between your index and middle finger. That way when you pull up on the handle, you put pressure on both sides of the handle, which pulls the handle straight up. If you put all of your fingers on the same side of the vertical shaft, then folks have a tendency to pull up at a slight angle, thus putting an angled pressure on the plastic handle.
C3UZ-2760-A .. Parking Brake Handle-Includes Pin / Obsolete
No Ford dealer or obsolete parts vendor has any.
The 1960/65 Falcon/Comet; 1962/65 Fairlane & 1965/66 Mustang handle (C0DZ-2760-B) will work, but BRAKE will read upside down.
C0DZ-2819-A .. Parking Brake Handle Pin / Obsolete
MCDONALD OBSOLETE PARTS in Rockport IN has 5 = 812-359-4965.
Does it operate like a pull up to engage and a twist to release?
MikeS29
64
03-23-2019 11:32 PM
8lug
54
09-25-2015 08:16 AM
glruff
Florida Chapter
86
03-13-2011 08:13 PM
rcav8or
15
07-17-2008 09:55 PM
