1978 - 1996 Big Bronco
Breather Question
Old Sep 14, 2003 | 11:21 PM
AYoungblood's Avatar
AYoungblood
Breather Question
I have blow back into my air box, now my question is, can i just run the line to close to the ground with no filter and lit it drip (i do very minor off road, no water more than 6-10 inches.), but mostly road driving.
If not, what can i do with this? Is there any fixes?
If you look here I talked about it, but really didnt get into it.
Old Thread
Adam
Old Sep 15, 2003 | 01:39 AM
greystreak92's Avatar
greystreak92
Breather Question
Older (higher mileage) 302's and 351's are prone to greater amounts of crank case blow-by. Originally, before emissions restrictions, the breather was merely an open filter atop one valve cover. So, running the engine that way wouldn't do any damage that I can think of. The concern is if you have to pass a visual inspection for emissions equipment. (Of course there are ways around that temporarily too).
Old Sep 15, 2003 | 02:33 PM
DW2455's Avatar
DW2455
Breather Question
yup what he said, but also check your PCV valve and make shure it working and the line to it are all hooked up.. DW
