Fuse box really located here?
Old Jan 29, 2018 | 01:42 PM
man7sell's Avatar
man7sell
Trouble shooting some lighting problems and want to start with checking a fuse. So really, the fusebox is located behind the light switch and upside down so you can even see the fuses? For our convenience? 63 F100
Old Jan 29, 2018 | 01:54 PM
Kirkb1's Avatar
Kirkb1
Yeah, looks like my 1962 F100. Between my ADD and OCD i break out in a cold sweat lol
Old Jan 29, 2018 | 02:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C2AZ-11A647-A (replaced COAF-11A647-B) .. Headlamp Switch Junction Block (aka fuse panel) / Obsolete
1960/64 F100/600 & full sized Ford Passenger Cars; 1961/67 Econoline.
Pic of 1964 (same as 1961/63) F100/600:
Old Jan 29, 2018 | 02:16 PM
man7sell's Avatar
man7sell
Thanks numberdummy. Now how to physically get to the fuses?
Old Jan 29, 2018 | 02:19 PM
TA455HO's Avatar
TA455HO
Lead Gopher
https://www.ford-trucks.com/forums/1...ord-ff100.html
I find the search function to be outstanding, but I know others have troubles....nothing like a good query....
Chad
Old Jan 29, 2018 | 02:32 PM
man7sell's Avatar
man7sell
Chad
We did that simultaneously just finishing reading the thread. All that to change a fuse.
Old Jan 29, 2018 | 03:03 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Ya, you can see why I like 1966 year - well one good reason anyway...
Chad
Old Feb 2, 2018 | 04:17 PM
man7sell's Avatar
man7sell
After some contortion managed to get to the fuses (Getting too old for upside down work). Measured the fuse voltages either side of each with ignition on and there you go. One fuse has no voltage either side. It's the very small one and I think its horn, cigarette lighter, and dome light. At least those are all inop.
Old Feb 2, 2018 | 05:24 PM
Tedster9's Avatar
Tedster9
Well there's only four (4) so it's not too bad. lol
Old Feb 2, 2018 | 10:00 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
If you have no voltage on either side of the fuse, I don't think the fuse is your problem.
Old Feb 4, 2018 | 11:25 AM
man7sell's Avatar
man7sell
There are 5 and it's the little 1amp fuse that has no power either side. Need to check the wiring coming in the back.
Old Feb 4, 2018 | 04:50 PM
Jolly Roger Joe
According to this drawing, your cigar lighter is protected by a 14 amp fuse. Black wire with green stripe to the fuse box.
The horn is not fused. Power comes straight from the hot side of the starter relay. Yellow wire.
http://www.fordification.info/tech/i...tlighting2.jpg
According to this schematic, the dome light is protected by a 7.5 amp fuse. Black wire with blue stripe.
I bet the 1 amp fuse will have voltage on one side if you crank the light switch counter clockwise to power the dome lamp. I can't find a fuse labeled as 1 amp, but I bet that's it.
Old Mar 14, 2023 | 10:02 PM
Bryan Feil's Avatar
Bryan Feil
3rd Gear
Do you know where to buy this fuse box? I am looking at getting a replacement but don’t seem to see it on any part websites.
Old Mar 14, 2023 | 11:24 PM
Tom H So. Ca.'s Avatar
Tom H So. Ca.
This post was dredged from the deep end.
Bryan. Sorry I can't help.
This thread coming up is perfect timing. I was just cursing the fuse block and it perfect location for a contortionist. Lay on your back with feet out the door, twist just right, then try to see and reach around the parking brake rod. Yeah, good luck!!
WHY!!!!!!
Tom
Old Mar 14, 2023 | 11:52 PM
66F250_4x4's Avatar
66F250_4x4
Check Numberdummy's post above. p/n C2AZ-11A647-A
A quick google search finds a couple on ebay and plenty via rearcounter https://www.rearcounter.com/C2AZ-11A...rts183721.html
