Sponsored by: Real Truck
confused
Old Jan 30, 2018 | 10:56 PM
jose0504's Avatar
jose0504
I tried to move the lever on ignition switch to see if I could find a spot where it would turn everything off but no luck, so then I took the ignition switch off (which is brand new, I bought a new one) and even with the switch completely unplugged everything still had power to it. I will look at the trailer light connections when I get off work in the morning. Thanks guys for the info.
Old Jan 31, 2018 | 08:12 AM
jose0504's Avatar
jose0504
well I checked my trailer connection and everything seems ok there, no fried wires or corrosion. I haven't checked the door switch yet but that's the only thing I have left that I haven't checked. Someone suggested I change the ignition switch before I do anything, I have a new one and it still does the same thing as the old one, everything still comes on even with no ignition switch plugged in.
Old Feb 14, 2018 | 08:43 PM
SDSC4X4's Avatar
SDSC4X4
Did you check the multi-pin connection in the engine compartment on the firewall below the brake booster/steering column? I would pull it and inspect for water and corrosion. Just a thought....
dmz132
1997 - 2003 F150
Jun 2, 2018 09:02 AM
Honey Creek
Nov 24, 2006 09:17 PM
tomf250
Apr 28, 2005 05:23 AM
2000F150EXcab
1997 - 2003 F150
Jan 6, 2004 09:59 PM
blitz10
Feb 21, 2003 08:30 PM
