1978 - 1996 Big Bronco
leaky bronco
Old Sep 14, 2003 | 10:43 PM
65kcoupe's Avatar
65kcoupe
leaky bronco
I was cleaning the back seat area earlier and i noticed water in the driver side ash tray... Has anyone ever experienced this? Where could the water be coming from? I guess the most obvious place to look would be the top...but i dont see how it could get in the ash tray....
Old Sep 14, 2003 | 10:54 PM
christop43's Avatar
christop43
leaky bronco
Could be the top, but I would also check to see if you have cracks in the sheet metal on the rain gutters above the drivers side door. This is a very common problem with Bronco’s.
Old Sep 15, 2003 | 01:43 AM
greystreak92's Avatar
greystreak92
leaky bronco
Ditto to Christop43's post. I would suspect the rain gutter cracks long before the top being a problem. Those blasted cracks let water n and all the way down to the rocker panels if it rains hard enough. I have pics of the kind of cracks we are talking about in my gallery.
Old Sep 15, 2003 | 09:37 AM
65kcoupe's Avatar
65kcoupe
leaky bronco
How do I go about fixing this? Is there a sealant i can put on the gutter? or does it have to be replaced?
Old Sep 15, 2003 | 10:24 AM
Will_01_GT's Avatar
Will_01_GT
leaky bronco
Clear silacone is what I used to fix, run a bead down both rain gutter, if you really neat you can't even tell
Old Sep 15, 2003 | 03:45 PM
lars915's Avatar
lars915
leaky bronco
Make sure you pull the trim panels behind the seats and clean out the area below the seat belt retractors. This area collects a lot of dirt and will retain the moisture that came in through the drip rail cracks. This will cause the rockers to rust out below the retractors. If you clean it out and dry it up, you should avoid future problems. I also recommend drilling a couple holes in the B-pillar near the retractors to speed up drying the inside of the pillar.
Old Sep 15, 2003 | 05:45 PM
greystreak92
leaky bronco
Ford did issue a TSB on this problem and it has been discussed to death. Do a search for the topic. From what I have gathered, the TSB is available but the necessary components to perform the repair are not. I'm not sure anyone has actually ever seen the components that Ford claims needed to be used in the repair process. And short of the body work to fix them, gobs of some type of sealer is about the only thing I have ever heard anyone using.
Old Sep 16, 2003 | 02:18 PM
lars915's Avatar
lars915
leaky bronco
Ford stopped performing the TSB some time ago. Several years IIRC.
Old Sep 16, 2003 | 04:49 PM
AlM's Avatar
AlM
leaky bronco
yo Larsssssss!
Any new tech articles?
Mr7.50headsup
22
Nov 20, 2013 06:15 PM
smallello
May 28, 2012 07:06 AM
Dads79
Jan 30, 2008 02:07 PM
warmdye
May 25, 2002 12:16 AM
onewaymike
Feb 5, 2002 04:56 PM
