Fuel issue if someone could help!
Old Jan 28, 2018 | 08:01 PM
Rexmortis's Avatar
Rexmortis
69 Ford F100 runs fine for 10mins. Starts up. Has a full tank of gas. Then dies as if it's out of gas. I had removed the secondary tank long ago and got rid of the fuel line. I tried adjusting the aux tank switch both ways and truck still won't start. Then after about 2hrs the truck starts up fine. Any clue ?
Old Jan 28, 2018 | 08:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Look at the fuel pump, does it have a round metal canister on it? If so, there's a corrugated paper cartridge filter inside.
Some people are unaware, so they install an in-line fuel filter. Meanwhile the paper filter is getting more clogged up every day.
Old Jan 28, 2018 | 08:08 PM
Rexmortis's Avatar
Rexmortis
I will definitely check this...thank you
Old Jan 29, 2018 | 06:57 AM
john jamieson's Avatar
john jamieson
When it dies, immediately open the gas cap and try to notice if there is auction in the tank. Some people have had issues with newer non-vented gas caps
Old Jan 29, 2018 | 07:09 AM
ultraranger's Avatar
ultraranger
Do you still have a points ignition? If so, put a timing light on it, start the engine from a cold start and just observe the flashes from the timing light as the engine gets up to operating temperature.
If the condenser is bad, you'll notice the flashes from the timing light becoming erratic as the engine warms up. If this is the case, it will tell you you have an ignition problem (bad condenser) and not a fuel problem. --I went through the same symptoms a couple of summers ago and I too (initially) thought it was a fuel problem. It turned out to be a bad condenser.
Old Jan 29, 2018 | 08:08 AM
orich's Avatar
orich
What engine do you have for one thing.
If you have a automatic choke that's not opening correctly an stalling the motor out..
Orich
Old Jan 29, 2018 | 07:22 PM
Rexmortis's Avatar
Rexmortis
This very well could be the issue...I'll take a look thank you!
Old Jan 29, 2018 | 07:23 PM
Rexmortis's Avatar
Rexmortis
I did just replace my gas cap about a month ago....
Rexmortis's Avatar
Rexmortis
Orich
FE 360. It's manual choke
Old Jan 29, 2018 | 09:06 PM
orich's Avatar
orich
check all rubber gas lines at pump an the main lower tank switching valve for any cracked line that can suck air or leak gas..
What have you done to solve the problem??
How long has this been happing ?
Orich
Old Jan 30, 2018 | 09:33 AM
Ed Morrison's Avatar
Ed Morrison
I had same issue on a 62 falcon and it turned out to be coil. When coil got hot car would die let cool off and it would start.
Old Jan 30, 2018 | 03:50 PM
MIKES 68 F100's Avatar
MIKES 68 F100
any fuel line getting hot ? could be vapor lock
Old Feb 1, 2018 | 01:33 PM
Rexmortis's Avatar
Rexmortis
Apparently it was my points eliminator i put in to replace my points...haha an old time ford guy told me...you'll be walking with those...back to points!
Old Feb 1, 2018 | 01:35 PM
Rexmortis's Avatar
Rexmortis
Thanks for all the help guys! All these suggestions are great and make me understand a little bit better things I need to possibly look at in the future.
Gus thanks you too!!
Old Feb 1, 2018 | 01:39 PM
Freightrain's Avatar
Freightrain
Which brand and did you run it off the existing points wire?
They say it needs a full 12volts and the coil wire has a resistor wire that cuts the running voltage to about 9v. The new electronic conversion do not like low voltage. I just know I've heard that common story of failure and that is what everyone says is the issue.
