I ran some G2 1.25" spacers on my 95 150. The old wheels I had I needed them. But now I got a 15x10 wheel with a 46mm offset. Still rubs with a 4" suspension 3" body with 35's only at full lock but not too bad. I went thru at least 3 sets of wheel bearings in 1.5 years. I had constant issues running 33s let alone 35s. After I took them off I noticed right away better brakes, less vibration, and less highway vibration. Don't recommend. Save your money and get wheels with offset
Explain the difference in the load that your wheel bearings/brakes see when running a spacer/wheel or just a wheel with a back space measurement that that puts the wheel in the same place.
Sounds like you're thinking of an adaptor that has its own studs. A spacer is more of shim with holes in it for the existing studs to pass through.
My issues with spacers is the fact a thick enough spacer will prevent the center of the wheel from registering on the hub, making the assembly stud-centric and not hub-centric. Might not be bad on a 3/4 ton with eight 9/16" studs, not overloaded. On the other hand, a 1/2 ton having only five 1/2" studs, might not be too safe when typically overloaded by a Gen 7-8-9 owner.
Just my $0.02 USD worth.
1/2 tons in the 92-96 OBS are lug centric - centered by the lugs, not by the hub
Are 3/4 + tons hub centric?
My '97 F250HD is hub-centric. That's why the factory Alcoa aluminum wheels used more of a hubcap rather than a push-through cap. No room for that push-through. And, most aftermarket wheel push-through caps won't work due to that reason. I believe my '00 SD dually was that way, too.
So on an F150, the center pilot bore of the wheel is not snug to the hub? Free to rattle around before the lugs are tightened?
Wheel spacers are 100% safe IF they are installed properly and are the right spacer for the application. If you are using the factory wheels they are hub centric so you must buy a hub centric spacer. If you use the ones that bolt to the factory studs and have there own studs (this is what I recommend) you have to make sure the factory studs don't stick out past the mounting surface of the wheel, if they do then you have to trim the wheel studs down. When you Install the spacers you need to use thread locker on the inner studs and torque them down to spec with a torque wrench. I have been running 2" hub centric aluminum spacers with my factory wheels for over a year without a single issue.
Initially, I was going to install the 1 1/2" spacers/adapters, but too much would have had to have been trimmed from the rear wheel studs...so I went with the 2" instead. Even then, I had to take about 3/8" off. I run factory Alcoas...no problems...and CK the torque of the studs when I rotate tires...always tight.
