Ratz...
Old Jan 28, 2018 | 09:30 AM
DeeDubz's Avatar
DeeDubz
Ratz...
How do you guys keep rats or other animals out of your toy haulers / campers? I just got my trailer back from the shop. Apparently a rat chewed on the fuel line amongst other things. He said their getting in from climbing up the tires. They recommend those black boxes (bait stations). I have a pretty large open field behind my property were I keep my trailer. Looking for ways to keep these a holes out.
Old Jan 28, 2018 | 11:01 AM
senix's Avatar
senix
keep the grass or what ever cut real close.
I have glue traps all though out my rig, in behind drawers, under cabnets and in the bathrooms under the sink where the lines come in.
Try some lime around the wheels.
Old Jan 28, 2018 | 11:22 AM
Chuck's First Ford's Avatar
Chuck's First Ford
the problem I see with "Bait" they will die where its hard to get to... and will smell up the trailer real bad.
seal up any area they can get into...
no food stored in trailer.
traps outside of trailer.. aka under trailer and near wheels/jacks.
even a few traps inside of cabinets... but check often.
Old Jan 28, 2018 | 12:22 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
...or you SURE it's rats/rodents. What about the tree rats (squirrels) variety ? They ate into my engine wire harness badly... had to replace the whole thing. Over $1k. My insurance covered it.
Old Jan 28, 2018 | 08:58 PM
Ferguson65's Avatar
Ferguson65
We use the Valterra sniff and stop kits. Some online reviews are horrible, but another couple recommended it to us at the rv dealer. We have used it the past 3 winters and have yet to find ANY sign of mice in the trailer when we open it up in spring. We remove all food products for winter and give it a thorough cleaning before we pack it up. Grille stays in trailer and has yet to cause an issue. Spray perimeter of floor with peppermint smelling stuff, and add that to backs of cabinets and nooks and crannies that the little buggers love. Sprinkle stuff on ground under trailer and spray around springs, tires and landing gear.
I don't use glue traps or poison for the reasons previously stated. I'd rather keep them out in the first place then have them curl up and die somewhere I can't find.
Old Jan 29, 2018 | 08:36 AM
HRTKD's Avatar
HRTKD
My first line of defense is bait. I think I'm using D-Con. Those are outside near the tires, one on each side of the trailer. In the summer I'm replacing the bait cube at least once a month. Less frequently in the winter.
I put one bait trap inside, just in case. I usually run three "servings" of Fresh Cab, one behind each set of floor cabinets. It makes the trailer smell like freshly cut pine trees.
My trailer is parked in a gravel storage lot with a billion other trailers. Mine is close to the edge where there is a field five trailers over.
So far I haven't had any critters inside, but they have certainly been outside taking the bait.
Old Jan 30, 2018 | 10:32 AM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
A Texas rat snake will take care of them!!
srkr
May 3, 2025 04:02 PM
DavidK2017
2015 - 2020 F150
May 11, 2017 02:14 PM
Blue_Oval1
All Things Towing
Jul 22, 2014 09:12 PM
tndiesel
All Things Towing
Jan 3, 2008 01:09 AM
dcexplorer
General Automotive Discussion
Apr 18, 2004 09:10 PM
