Battery Jumper Pack
Battery Jumper Pack
I am looking for one of them for the cars and lawn equipment, just in case. What does anyone who has used them on the Powerstroke recommend? I'd like to get one that covers everything, just in case I do something stupid like leave the lights on overnight.
What should I be looking for, spec wise that will work? Sure, best is a starter hooked up to the wall but that might be a little too large to carry around and be an issue if there is no outlet.
TIA
TIA
I carry a JNC 660 jump box, on long trip or in extreme cold, it's larger but has a replaceable battery and works well. I bought it used off eBay because it wouldn't hold a charge $15, new battery for $40 and it's worked flawlessly since.
Jump-N-Carry
Link: http://a.co/0o5KA0p
If If I ever replace it I'd probably buy something like this:
NOCO Genius Boost Amp 12V UltraSafe Lithium Jump Starter
by NOCO
Link: http://a.co/eYicBw4
If you're looking for a set of HEAVY DUTY jumper cables at an excellent price, these are incredible!
https://www.ebay.com/i/272074400813
Jump-N-Carry
by NOCO
If you have dead batteries on a cold winter night far from an outlet... might I suggest a Honda generator, a battery charger from hell, plug in the block, and go back to the hotel room for some coffee and breakfast - maybe watch a movie. The only time in my life that I had to call AAA was in a parking lot in downtown Reno with two dead batteries and 7 degrees F. Nothing... and I mean nothing normal jumped the truck. Stinky was DOA without serious time on a regular charger and the block plugged in - or serious charging from a truck rigged to slap the amps to cold dead batteries.
With two good batteries, we're supposed to store 1700 CCA - and a jump might provide 500. A big chunk of that 500 amps is hogged by the glow plugs, and the starter gets the leftovers. If you are dead serious about buying a battery jumper pack, TWO of something like below might get it done.
That NOCO is cool, but it says right on the page it's good for diesel engines up to 3 liter. Here's the one for over 6 liter diesels: [ ] Remember, it charges from USB only - not a wall outlet. So... it takes days to charge it up to full.
That NOCO is cool, but it says right on the page it's good for diesel engines up to 3 liter. Here's the one for over 6 liter diesels: [LINK] Remember, it charges from USB only - not a wall outlet. So... it takes days to charge it up to full.
I've got NOCO, Snap-On and Craftsman. I have had to use all three plus a Jump to start some of the Trucks. The NOCO's are 1,000 AMP, the Snap On and Craftsman are 900 AMP.
IF the Batteries aren't "gone", I can use two 1,000 AMP NOCO's (one on each Battery) if you let them on for say 20 Minutes and then give her a Whirl.
I also have the 400 AMP for the Lawn Tractor's and such which seems to work well.
Like Rich says, the Glow Plugs eat a lot. One trick I learned long ago was to put a Jump Box by itself connected to the GLOW PLUG Relay before turning the Key with the other on the Batteries for a few minutes.
"GB150 [USB charging]
11 hours at 2A
22 hours at 1A
45 hours at 0.5A
[12V Fast Charge (60W)]
2-3hrs at 5A"
"Fast charge" would be putting the jumpers on something that has 12 volts - like a charger or a battery on a running engine.
Have been considering one of these that can be charged via 12v.
Have the idea of installing it behind the back seat so that it will always charge when the truck is on. All the options I have looked at put this setup in the $200-$300 range.
Jumper cables are a lot cheaper, lol.
Saw someone who had a 6.0 at work. Parked all day and it wouldn't start at night. He got his wife to jump it with some small car. Of course it wouldn't work. I let him hook up to the Powerstroke and he got it running
that is why finding one of these jumper packs that can be charged via 12v gets spendy.
you definitely want one big enough to get the job done. maybe I should start dropping hints to the wife for an up coming b-day
