CNC Fab
Old Feb 27, 2019 | 12:48 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I too can vouch for the service and support from Corey at CNC Fabrication. I have been a customer of his many times and plan to be many more times.
Old Feb 27, 2019 | 03:36 AM
SCStroker01's Avatar
SCStroker01
Squirrel,
Is that your sensor for fuel pressure coming off of the tee from CNC fuel line?
Old Feb 27, 2019 | 09:11 PM
Squirrel13's Avatar
Squirrel13
Yep that is the FP sensor
Old Mar 3, 2019 | 11:43 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
For those who have installed Corey's halo / flagship / original product... the CNC Fab four line feed kit... have you really noticed a difference? Did it address the hot idle "knock" that some have called cackle? Did it effect Perdels in #8? Does it excel in accomplishing what Clay's halo / flagship / original product... the FRX purports to do, which is to prevent starvation of #8 when #6 spills a high pressure spit in the rail between shots? If you have singles, how could this benefit even be noticed?
Old Mar 3, 2019 | 11:48 AM
Squirrel13's Avatar
Squirrel13
I havent started mine yet and I have no data to compare it with. Truck came home from dealer and has been in rehab since Labor Fay
Old Mar 3, 2019 | 01:04 PM
SCStroker01
I’m in the process of adding Corey’s 4 line kit and DieselORings billet FPR with higher PSI spring. I believe this is the best of both put together. Corey ran this setup on his own truck.
Old Mar 6, 2019 | 04:20 PM
coreyATcncfab's Avatar
coreyATcncfab
Yup, the very first kit I ever made has been on there for about 7yrs or so now.
Old Mar 6, 2019 | 04:23 PM
SCStroker01
Which spring would you recommend?
Old Mar 6, 2019 | 04:29 PM
coreyATcncfab
Keep your pressure no more than 65psi. Above that is pointless for the injectors, but most say dont go below 45. Too high of pressure can crack your bowl.
Old Mar 6, 2019 | 05:19 PM
brian42's Avatar
brian42
Veteran: Navy
Which spring would you recommend?​​​​​​
I used the gold (middle spring) which says it's good for 62-65 psig fuel pressure.
At idle my fuel pressure is around 62-63 psig and doesn't dip much below 60 psig during normal driving. If I really hammer it in a street tune fuel pressure dips to the low 50's psig (52-53 psig) and quickly recovers.
RobRoy7768
Mar 14, 2019 07:26 AM
Greg Hamilton
Mar 6, 2019 07:59 AM
ohboy44
2009 - 2014 F150
Jan 10, 2008 06:00 PM
jh8128
Missouri Chapter
Mar 31, 2007 10:55 PM
Mil1ion
General Automotive Discussion
19
Nov 4, 2006 04:25 AM
