Sponsored by: Real Truck
4x4 Shifter assembly
Old Jan 24, 2018 | 02:14 PM
Chaosracing's Avatar
Chaosracing
At work we have a 2004 F250 4x4. The 4x4 shifter is coming apart. It looks similar to this one https://www.ford-trucks.com/forums/1...sfer-case.html Where it piviots on the rubber bushing, it keeps slipping off. Is that bushing supposed to be pressed into the shifter and it spin on the bolt, or is there a retention washer that is supposed to be there? I have a picture of it out of the truck, but cant post now, but figured I would see if anyone had information. I can not find anything about this style shifter.
Old Jan 24, 2018 | 03:09 PM
Chaosracing
Here is a aftermarket with pictures. I can not get pics to upload for some reason. qu20548 - Torque King 4x4
Old Jan 24, 2018 | 06:54 PM
00t444e's Avatar
00t444e
I had that same issue with mine. I took the shifter into a trucking supply store and they where able to find me a bushing and a bolt that would fit it. The bushing was a leaf spring bushing so I had to cut it in half so it would be short enough to fit. It works great now.
Old Jan 24, 2018 | 06:56 PM
00t444e's Avatar
00t444e
Does this look like what you need https://www.ebay.com/itm/FORD-OEM-LE...-/181790179768
Old Jan 24, 2018 | 09:15 PM
Chaosracing
Almost, the bracket on ours only has 2 holes on it. But looking at my picture I could cut off the extra hole. Don't know if the boss wants to spend that much though. Your bushing idea has me thinking though.
I am assuming you had to press the new bushing into the bracket?
Old Jan 25, 2018 | 07:15 AM
00t444e's Avatar
00t444e
I pressed it in with a vice.
Old Feb 2, 2018 | 10:30 PM
Chaosracing
Well good news, was able to source one from a junkyard. Was practically brand new and they only charged $50.
MD79TA
Jan 11, 2015 07:03 PM
torquemeister
Aug 27, 2014 09:16 AM
torquemeister
Aug 26, 2014 10:03 PM
henryc
Aug 10, 2012 05:46 PM
