Plug and coil
Old Jan 23, 2018 | 12:44 PM
James Thompson's Avatar
James Thompson
Plug and coil
I've changed both of these about 4 months ago less than 1500 miles on it and its miss fireing again on the same one cylinder one
Old Jan 23, 2018 | 12:47 PM
alloro's Avatar
alloro
What about the fuel injector, or the wiring to the coil, are they good?
Old Jan 23, 2018 | 03:07 PM
steve(ill)'s Avatar
steve(ill)
My experience is if you have a 5.4 motor, it is almost always the coil/ wire....... If it is a 4.6 motor, I have seen several injector problems that originally I thought were COPS misfires.
Old Jan 23, 2018 | 10:49 PM
rander101's Avatar
rander101
Did you use OE coil & wire? There are a number of reports of non-Ford parts failing prematurely.
Old Jan 26, 2018 | 11:58 AM
StarFox's Avatar
StarFox
Also too, if you didn't clean out the carbon from the spark plug threads and below, you may not have seated the plug as well as you thought and have carbon blowing past the plug. Did you get a ticking sound at the same time?
mossberg500
Modular V8 (4.6L, 5.4L)
Dec 22, 2017 10:25 PM
tristopher1234
1997 - 2003 F150
Jul 19, 2010 01:47 AM
lesser mike
Oct 20, 2007 07:10 AM
speedovr55
Dec 11, 2004 02:28 PM
mudyone
1997 - 2003 F150
Nov 4, 2003 06:38 PM
