1973 tailgate mounting help.
Old Jan 23, 2018 | 09:19 AM
Ug666's Avatar
Ug666
I picked up a tailgate from a junkyard as mine was missing. I took all the hinges and stays/pivot points HOWEVER I come back to fit it to mine and there's no nuts behind the l/h pillar to mount the lower pivot point on.
Being a rainy day and suffering from flu I'm hoping I can find someone who will be able to let me know if these are mounted on a bracket/keep plate or welded on (captivated nuts) as I'm not going out to start stripping the thing down today but can order parts online ready for when I feel better.
p.s. checked all the threads I can see that look relevant and checked online at LMC etc but can't seem to identify the fitting method.
Old Jan 23, 2018 | 09:27 AM
Ug666's Avatar
Ug666
For clarity:
From LMC
Truck Parts and Truck Accessories
The nuts that Item 8 bolts in to.
https://imgur.com/a/fc94R
Old Jan 23, 2018 | 02:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Jan 23, 2018 | 04:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
There is a floating bracket that is ? 1/2" W x 3"L ? with threads tapped into it. The strap is retained by a cross strap that is tack welded on each side in 2 (?) places to the bed.
Time for some close quarters, work but you should be able to bolt and nut the outer hinge piece (43018) in place.
If you have a local JY I am sure a #4 flat tip should get the cross strap bent out of the way enough to get the bracket off.
Those pics are on my "parts" beds....the last pics is a rusty 76 and other pics are off 79 beds.
Old Jan 23, 2018 | 07:37 PM
Ug666's Avatar
Ug666
That's brilliant tyvm.
smashclash
13
Dec 4, 2016 08:31 PM
ktm4012
Aug 1, 2016 05:59 PM
1974 f100
Apr 7, 2015 09:20 PM
ingo
20
Jul 4, 2005 05:21 PM
