2013 Ford E-150 Rear heat not working
Hi fr420, welcome to the group. My '96 has a vacuum controlled valve close to the rear coil that controls flow. You might try working the valve's arm back & forth to see if you detect hot flow thru it. Should it need replacement I've read the lower priced all plastic units don't last long. The motorcraft valve is worth the extra cost ($8 vs $25)
jts140
10-29-2012 08:15 AM
