EDO4 Max shift points
Old Jan 20, 2018 | 07:02 PM
DMANDIE's Avatar
DMANDIE
I'm sure they are somewhere but I cannot find what the max shift points are for an edo4 transmission
Old Jan 20, 2018 | 09:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Do you mean E4OD? The shift points vary by engine. The maximum RPM for a shift will be lower on a diesel than a gas engine, for example.
Old Jan 20, 2018 | 11:04 PM
DMANDIE's Avatar
DMANDIE
oh yes E4OD *brain fart* but more or less biult motor with stinger performance megasquirt ECU going to be getting a US Shift controller.
but I cannot find how much RPM a stock transmission can spin to
Old Jan 21, 2018 | 08:10 AM
humphrey169's Avatar
humphrey169
It's the engine that limits that. If the tranny can handle 11,000 but the engine is good till 8,000 then you get to pick up pieces on the road. My thinking any way
Old Jan 21, 2018 | 08:44 AM
Eddiec1564's Avatar
Eddiec1564
I know on my 95 E350 with the 460 engine, the E4OD will shift at ~4800rpm at WOT. The 92 F150 with a 302 shifted around ~5200 at WOT I recall.
I haven't driven a I6 300 yet(soon to replaced the AOD with E4OD in my 89 F250) so my estimate would be around 4000 to 4800 RPM at WOT. The big I6 300 engine looses all power after 3800 rpm and winging that engine too high is not good!
Old Jan 21, 2018 | 09:23 AM
DMANDIE's Avatar
DMANDIE
Okay good to know, my F-150 351w has been sitting for 4 years just about get it back on the road with a new motor and all but I know it Max shifted at 3800ish to 4000 and I didn't know safely spin it to 5 grand guaranteed putting 400 horse on a virtually stock rebuilt transmission and then abusing it isn't the best idea but definitely a lot more of a Power Band being needed there
Old Jan 21, 2018 | 09:26 AM
humphrey169
What is this controller you are going to use
Old Jan 21, 2018 | 09:34 AM
DMANDIE's Avatar
DMANDIE
and that's my thought exactly just in reverse I know my motor will probably run the 5500-6000 if needed peek power still being 4800-5400. . . but if the tranny stock only handled 5000rpm safely before risking it going *kaboom* it's just something I want to know find out, and I truly don't know Transmissions yet I can build a motor but Transmissions are another language to me still so I might as well ask
Old Jan 21, 2018 | 09:35 AM
DMANDIE's Avatar
DMANDIE
Us shift quick2 or quick4 if the money's there
Old Jan 21, 2018 | 05:27 PM
Briansshop's Avatar
Briansshop
You don't need to be concerned about rpm hurting the trans
fhafer
Dec 14, 2015 04:03 PM
littleme13
Jul 24, 2009 02:41 PM
woodly1069
Jun 5, 2007 12:34 PM
