Dashboard bulb replacement.
Old 01-20-2018, 12:04 PM
columbia1spring's Avatar
columbia1spring
columbia1spring is offline
I have a few bulbs out in the dash. Can I access then by reaching up or must I remove the dash?
Old 01-20-2018, 12:12 PM
LONCO's Avatar
LONCO
LONCO is offline
I have always just taken out gauges and just rested it on steering wheel, but you could probably reach it from backside. It would require a small hand and be difficult.
Old 01-20-2018, 12:58 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Lower pic: 13711 plastic bulb sockets twist into cluster thru 10K843 printed circuit board, bulbs are 13466
Old 01-20-2018, 01:48 PM
deich's Avatar
deich
deich is offline
I just replaced the one bulb on the drivers side cluster if I had many to do I would pull the the whole thing... It was a PITA
Old 01-20-2018, 06:25 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,335 Likes on 2,481 Posts
What looks easier? Especially if you have a/c vents to deal with.
Dash bezel/instrument cluster removal walk thru. #1 https://www.ford-trucks.com/forums/1...l#post14880899
Same "ford truck info and then some" thread post #78 is another walk thru.
Old 01-20-2018, 08:21 PM
FordFanboy's Avatar
FordFanboy
FordFanboy is offline
If you still have the original cluster, this would be a good time to look at upgrading it. In the 70s they used a plastic compound that degrades very badly. If it's original, it will likely crumble when you pull it out.
​​​I'm not sure when they switched to the new plastic. I got my replacement from a mid 80s van. The vans used the same instrument cluster as our trucks well into the 80s.
Old 01-20-2018, 08:33 PM
NumberDummy
In 1975/79 they used a POS instrument cluster back made of a composition material that degrades very badly. If it's original, it will likely crumble when you pull it out.
​​​I'm not sure when they switched to the new hard plastic cluster back (1981). I got my replacement from a mid 80's Econoline van.
The vans used the same instrument cluster as our trucks well into the 80's.
OP's "About Me" profile: 1974 F100.
1973/74's did not use the same POS instrument cluster backs that could TURN TO DUST (before your very eyes!) that 1975/79's did.
1981: FoMoCo introduced hard plastic cluster backs for Econolines, these were also the "service part replacements" for the original POS backs.
E1PZ-10848-A .. Hard Plastic Cluster Back-Use with Oil/Amp GAUGES / Obsolete ~ Available NOS
1981/91 Econoline. Retrofit: 1975/79 F100/350; 1975/80 Econoline; 1978/79 Bronco.
E1PZ-10848-B .. Hard Plastic Cluster Back-Use with Oil/Amp WARNING LAMPS / Obsolete ~ Available NOS
1981/86 Econoline. Retrofit: 1975/79 F100/350; 1975/80 Econoline; 1978/79 Bronco.
Old 01-21-2018, 08:01 AM
Shortbox4x4's Avatar
Shortbox4x4
Shortbox4x4 is offline
led bulbs
Do yourself a favor....while you are replacing the bulbs go to led bulbs. I can actually see my gauges at night now. The pic. below was taken during the daytime. You can get the led bulbs in different colors. I went with green as you can see.
Old 01-21-2018, 10:34 AM
lasermike's Avatar
lasermike
lasermike is offline
I too went with LEDs. I used Superbright white and am still impressed with how bright they are and how well I can see the gauges now.
As for installing them, I’m still just flexible enough and stubborn enough to change them out with the cluster still installed. Didn’t even hardly cut myself!
Michael
Old 01-21-2018, 07:34 PM
dekeman's Avatar
dekeman
dekeman is offline
Couldn't agree more on the LEDs, just make sure they're good quality ones.
Went from being barely able to see to whoaaaa!
Old 01-22-2018, 08:15 AM
JD Q's Avatar
JD Q
JD Q is offline
Columbia1spring I apologize for the highjack but I too am interested in the Dash-light upgrade.
Dekeman and Shortbox4x4, tell us what LED bulbs you used. If you have the brand and/or part number please post. Thank you, highjack over.
Old 01-22-2018, 09:16 AM
dekeman's Avatar
dekeman
dekeman is offline
Bought them some time ago, but pretty sure it was
these ones these ones
These should work too These should work too
, but might be too bright.
Use one for my cab's cargo light also. Good light.
Just remember when installing, if light doesn't work at first, flip it 180 to correct polarity.
Old 01-22-2018, 10:52 AM
EQCMCAT's Avatar
EQCMCAT
EQCMCAT is offline
JD Q,
I upgraded my dash lights W/LEDs. Problem is I can't recall the company, but I kind of remember is was something like "HIPO". I'm also very happy with the visual improvement the LED bulbs made. Here a link that may help:
https://www.superbrightleds.com/vehi...=794&year=1977
Regards, Don
Old 01-22-2018, 11:04 AM
tlrtucker's Avatar
tlrtucker
tlrtucker is offline
Surprised it hasn't been said, but it's only about 6-8 screws to remove the gauge cluster. Literally takes 2 minutes to remove. Just be careful about scratching the plastic lens, the corners on the metal dash can really scratch it up.
Old 01-23-2018, 02:28 AM
Ozzie H.'s Avatar
Ozzie H.
Ozzie H. is offline
I also endorse the change to LEDs. Try to get one that is dimable just in case it's "too" bright.
Quick Reply: Dashboard bulb replacement.
