AnotherGow Plug Issue
Old Jan 19, 2018 | 05:20 PM
krypto2571's Avatar
krypto2571
Been driving my '04 4WD 6.0 Excursion, "Thumper," for a few hundred thousand miles, (Didn't BP the engine) I fixed Ford's screw-ups that plagued the engine last year, replaced just about everything that was replaceable but now I'm stumped.
New Glow Plugs just ain't glowing. New GP harnesses, new FICM, New GPCM, ran my Autek engine analyzer and came up with the following error codes in a cold pre-start mode:
P0098 - IATS2 Circuit Input (none)
P0404 - EGR Sensor A Circuit Low (none)
P0671 thru 0678 - Glow Plugs Circuit Failure (none)
P1000 - OBD Sys - Readiness Test Not Complete (none)
Glow Plug Coil Ontime - 0 sec.
I have two methods to start the engine. I either have to heat the block for an hour+ (depending on the air temp) or use the ether. Is my next step the PCM/ECM unit next to the battery$$$???
Looking for some good advice before I spend the big bucks.
Thanks.
PS: My spell checker failed to see that title to this problem is actually "Another Glow Plug Issue"
Last edited by krypto2571; Jan 20, 2018 at 01:14 PM. Reason: Spelling error - etc.
ranagent
15
Sep 8, 2015 07:37 AM
the_auto_tech
Aug 21, 2013 08:45 AM
MLCRI$I$ II
Mar 9, 2012 11:20 PM
1L243
Dec 31, 2011 09:04 PM
truckeemtnfords
13
Dec 23, 2008 10:13 AM
