B for binding or bumpsteer?
Old Jan 18, 2018 | 04:29 PM
humphrey169's Avatar
humphrey169
How could this conversion work? Yeah it's a van but same setup as a truck.
stlouis.craigslist.org/cto/d/1978-ford-van-1-ton-4wd/6459573634.html
Old Jan 18, 2018 | 04:30 PM
humphrey169
Dual track bars fighting each other. Must work but how. Super soft bushings that give?
Old Jan 18, 2018 | 04:51 PM
GoinBoarding's Avatar
GoinBoarding
The photo may be cutting off the answer. The ends of the track bars look to have something on their ends, that doesn't appear to be a standard eyelet + bushing. Strange either way.
Old Jan 18, 2018 | 04:52 PM
urbex's Avatar
urbex
It doesn't. Which is probably why it was parked while running, lol. If it had soft enough bushings to give enough to actually allow suspension travel, they would be FAR too soft to be even remotely close to effective as a track bar.
I'm sure the guy will claim that it's supposed to ride stiff as a board, because "That's how REAL TRUCKS RIDE!!!!!!!!!"
Old Jan 18, 2018 | 04:54 PM
urbex's Avatar
urbex
Radius arm frame side bushings. Or shock stud mount bushings.
Either way, there's no way it has enough travel to accommodate the change in direction that will be induced with the arms at that steep of an angle at ride height. Even if they were level at ride height, you'd only get a couple inches max of wheel travel before binding took place, AND you'd be replacing those bushings several times a year.
Calvin Thomas
Feb 17, 2019 03:11 PM
AllaboutMPG
Sep 29, 2013 09:44 AM
TinyWonder
Jan 24, 2011 06:16 PM
jad4
Jul 28, 2009 05:20 PM
superduty4x4
May 12, 2009 09:47 AM
