I’m swapping ‘78 351M from a 4X4 with a rear sump oil pan into a ‘79 F-150 2wd. Will the rear sump oil pan clear or do I need to swap the front sump 2wd oil pan back on the motor going in the 2wd truck?
I believe you can get away with that swap the other direction (2wd truck motor front sump oil pan into a 4wd truck). But I believe you are going to have to get a front sump pan. And different pick up tube.
