F250 6.7 2012 -- ignition switch/starting problem
Woke up to cold morning. Pressed remote start -- lights flicked, horn beeped .... didn't start.
Dash states, "service advance track" "trailer module (something)".
Insert key -- everything is normal.
Turn key -- all is normal but no glow plug light. So I wait....still no light.
Twist key to start -- NOTHING. no sound nothing.
Check batteries -- perfect. Remove and Test batteries- perfect. Reinstall batteries.
Try again -- still nothing at all when trying to to start.
All other electrical seems to work normally. (Seats, radio, lights etc)
Now what?
Now what?
Do you have anything plugged into ANY of the power ports? Anything plugged into the OBDII port? If so remove all of them and try again. I have read a couple posts about strange issues with the various modules while using cheap cell phone chargers.
If still no go, there is a large wire harness connector located on or near the rear of the Parking Brake Mount, try disconnecting and reconnecting that connector. This is a common issue that results in a huge number faults/messages displaying in the message center.
If neither of those work that's all I have. Maybe someone else will have something else to contribute.
Doucheatron
11-25-2012 09:02 PM
FixrUpr
03-04-2008 05:09 PM
