240/300 Distributor Gears
I was reading some threads on Cam Gear / Distributor Gear problems (wearing out gears faster than normal), the thread was about 302 & 351 motors and I was just wondering if the 300 has any problems in this area?
I am going to install a aftermarket RV Hydraulic cam with some type of electronic Distributor. Should I run the normal supplied cast distributor gear or an aftermarket Crane/Mallory/MSD steel gear? Maybe a brass gear? Will be running a regular pressure oil pump.
This is for a pump gas street motor, normal 5500 RPM range.
Denver
05-19-2011 06:47 PM
gnwalker
01-23-2010 11:44 AM
pootscratch89
13
05-07-2007 08:50 AM
lmadore
10-25-2005 07:53 AM
