About a duraspark distributor reluctor - Ford Truck Enthusiasts Forums
Old 01-18-2018, 02:39 PM
JohnSmith3524's Avatar
JohnSmith3524 JohnSmith3524 is offline
JohnSmith3524 is gaining momentum as a positive member of FTE.JohnSmith3524 is gaining momentum as a positive member of FTE.
Hi there all, Iím working on a spare diz project and would like to find a spare reluctor or two. Does anyone have the ford part number or any part number for a ford 6 duraspark reluctor?...a DISTRIBUTOR reluctor.
Thanks for any response.
Old 01-19-2018, 11:08 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
I'm not sure if those are available separately. At least I've never seen them. Unlike, say, the distributor gear, they're not a "wear part", so there's no reason to ever replace them (and as such no reason to make replacements).
Old 01-19-2018, 03:35 PM
Quote:
Thanks for the reply AB..Yes they DO make then separatley. Since they have to be removed for fine truning the dist cam advance, i have had quite a few off and re-used. I happen to be modifying a diz of mine and wanted a few spare ones. I see ebay has a few that originally came in a 70's maverisk six. Anyway..thanks for the response. I prefer stock Ford distributors, and parts ofr them are getting harder to find..my choice..In this case Im using that ford diz in another project that is not quite a stock application...
Others in another forum have reminded me that this reluctor is used in the smaller Ford sixes of the 70's as well so it seems to be available for service in other distributors.
Old 02-01-2018, 08:31 PM
F-250 restorer's Avatar
F-250 restorer F-250 restorer is offline
F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.
I went through this about 1 year ago when mine went out. Darn thing only lasted forty years. Well, after a lot of research, and being warned about the 'made in China' ones lasting one year, I bought NOS one on ebay. I took great comfort in seeing Motorcraft on the box.
Six Door Centurion F350 Powerstroke Project BrettMavriK 1987 - 1996 F150 & Larger F-Series Trucks 100 01-14-2018 12:08 PM
Mechanical Advance Issue rookieford 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-27-2017 01:29 AM
1970 Distributor build and curve-390 Classicdriver 1967 - 1972 F-100 & Larger F-Series Trucks 18 02-14-2017 04:57 PM
distributor pick-up coil install SteveH123 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-21-2016 05:59 PM
Duraspark pick-up phasing (electrically, not physically) rwjr Electrical Systems/Wiring 9 04-15-2016 09:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
