starter upgrade?
Old 01-17-2018, 09:05 PM
mcali2's Avatar
mcali2
mcali2 is offline
starter upgrade?
I am having issues finding info on doing the starter mod. What do I need to do or get? My truck seems slow on the cranking . It's not bad but after putting in 2 1000 amp batteries I feel it should be much faster. some times it is.
Old 01-17-2018, 09:18 PM
fordpride's Avatar
fordpride
fordpride is offline
Need a 2 bolt SD starter. I use a 02 year model. The only thing that need to me done is the small ring terminal need to be drilled out a little for it to fit the new starter
Old 01-17-2018, 09:19 PM
1fastktm's Avatar
1fastktm
1fastktm is offline
You have a couple options. A genuine Denso starter is a nice upgrade, bolts right up. Another less common upgrade is to use a 6.7 Powerstroke starter that has been modified. It bolts up to, the 7.3 and spins the engine over quite a bit faster than stock. I have a brand new Ford 6.7 starter modded setting in my garage.
Have you tested the starter for amp draw? What do your cables ohm out at? It sounds odd you say sometimes it starts slow.
Old 01-17-2018, 09:28 PM
fordpride's Avatar
fordpride
2000-2003 7.3 starter is a 2 bolt gear reduction starter and will spin it faster than the stock 3 bolt planetary gear starter and less work.
Old 01-17-2018, 09:43 PM
1fastktm's Avatar
1fastktm
1fastktm is offline
The 6.7 starter will spin faster than the Visteon/TYC 2 bolt OSGR starter in later 7.3s The 6.7 starter is an upgraded OSGR starter compared to the 7.3 version.
I like the 6.7 starter since it is brand new Ford. Only other option is a brand new Denso starter if you want Tier I or II Ford supplier. Otherwise you are stuck with remans, china copies, or "new" parts store starters.
Old 01-17-2018, 10:53 PM
mcali2's Avatar
mcali2
mcali2 is offline
Man, I'm electrical dumb. I can plug and play. It just seems it should spin faster. I could be wrong. The cables could be getting old. The ends are cut off and clamped into the post via the aftermarket battery clamp on a battery. How do I Ohm them?
Old 01-17-2018, 11:28 PM
mcali2's Avatar
mcali2
mcali2 is offline
to ohm them out I have to pull them off completely right or just one end and get the other end close enough for the meter to read?
Old 01-18-2018, 12:44 AM
Hit Man X's Avatar
Hit Man X
Hit Man X is online now
Received 1,221 Likes on 996 Posts
http://m.thoroughbreddiesel.com/denso-stock-replacement-starter-94-03-ford-powerstroke-7-3l.aspx
That is where I bought my Denso. Amazing difference.
Old 01-18-2018, 08:43 AM
knottyrope's Avatar
knottyrope
knottyrope is online now
ohming them out isn't going to give good results
measure voltage drop when cranking will tell you how bad they are
Old 01-18-2018, 08:49 AM
farmert's Avatar
farmert
farmert is online now
In my opinion, those clamp on cable ends are a temporary fix at best. They are just another place for corrosion to set in. I would go with new cables, either premade or you can get everything you need to make the cables from a good parts house. If you decide to make the cables use at least 00 gauge cable.
Old 01-18-2018, 09:06 AM
mcali2's Avatar
mcali2
mcali2 is offline
And how do I do that? Measure power at the battery post while cranking then the same at the starter?
Old 01-18-2018, 09:08 AM
mcali2's Avatar
mcali2
mcali2 is offline
Are you offering the starter for sale? how much?
is the 6.7 faster than the denso.
Old 01-18-2018, 10:00 AM
BuddyBarnes's Avatar
BuddyBarnes
BuddyBarnes is offline
6.7 starter modified? I have not heard of this. Can you explain?
Old 01-18-2018, 10:17 AM
knottyrope's Avatar
knottyrope
correct. if you have a big drop across the wire, that is a voltage loss to the starter.
I put my lead on battery post and to starter post to measure
then engine block to neg on battery
then test both with one battery removed and repeat on other battery
Old 01-18-2018, 12:15 PM
mcali2's Avatar
mcali2
mcali2 is offline
Now I'm more confused... how to you measure power if both leads are on the same side? + or -
I was thinking taking power reading at battery red to + post and black to Neg post. get reading. then go to starter, red to + on starter and Black to the starter base or grounding wire if there is one. is this the way to do it?
I'm just reading voltage right.
Also if there was a power drop would it not be the same if cranking or not cranking the engine?
thanks for edumacating me.
Quick Reply: starter upgrade?
