2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Aftermarket backup lights suggestions?
Old 01-23-2018, 02:19 PM
Bill Moulton's Avatar
Bill Moulton
Bill Moulton is offline
I have a 2017 F350 Lariat. It has all LED's and the BLIS box in the tail light assembly.
For my taste it needs much more backup light.
Has anyone found any good, bright aftermarket backup lights that could be wired to the Up-fitter switches
that are easy install and don't interfere with the trailer hitch or chain attachment points ?
Old 01-23-2018, 02:28 PM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is offline
Several have mounted flush mount LED lights in the bumper. No need to buy the expensive Rigid ones just get some off brand ones and they will add a lot of light. A quick Google search will turn up a bunch of them.
Old 01-23-2018, 03:11 PM
maypo59's Avatar
maypo59
maypo59 is offline
I bought some cheapies on Amazon, like $20 for the pair, mounted them under the bumper. Upfitter switch 2.. work great.
Old 01-23-2018, 03:30 PM
Buliwyf's Avatar
Buliwyf
Buliwyf is offline
Has anyone tapped a reverse light wire?
I'm eyeing these:
2017-2018 F250 & F350 ZROADZ Rear Bumper LED Light Mounts w/ Two Light Bars Z385471-KIT
But no luck finding pics or reviews here.
Old 01-23-2018, 03:56 PM
grege's Avatar
grege
grege is offline
I'm eyeing these:
Yes that has been done. Some even use a relay so they can turn them on with an upfitter switch too. I don't have the link to it but you should be able to find it with a search.
As for your ZROADZ link, that's out of my price range. I'm planning on getting some Nilight LEDs to go back there. Saw on here where somebody used those.
Amazon Amazon
Old 01-23-2018, 03:57 PM
Rustofer's Avatar
Rustofer
Rustofer is offline
Do you mean the truck reverse light? I was wondering if tapping into the trailer reverse light wire would work, or if the truck needs to see a trailer connected before it works?
Old 01-23-2018, 04:04 PM
jergle's Avatar
jergle
jergle is offline
I mounted 2 led lights under the trailer hitch wired to an upfitter switch. Also mounted lights under the cab just forward of the front doors that shine out toward the front and side. Makes it SO much nicer to be able to see all around the truck when you're maneuvering in the dark.
Old 01-23-2018, 04:47 PM
hinsong's Avatar
hinsong
hinsong is offline
Would you mind posting some pics of your front/underneath mounted lights? That sounds interesting and useful. Thanks!
Old 01-24-2018, 07:10 AM
jergle's Avatar
jergle
jergle is offline
Here you go. First 2 are the light on the front driver's side (similar light on the passenger side, and the bottom is my rear-facing lights.
Old 01-24-2018, 08:29 AM
macmac350's Avatar
macmac350
macmac350 is offline
night shot
great pictures can you give us a shot at nightof how much light on sides and back they give off?
Old 01-25-2018, 06:42 AM
jergle's Avatar
jergle
jergle is offline
Here are the side lights, looking out the driver's side window. Picture with light off and light on. These lights were only about $15 from Amazon. I didn't think to get a picture of the rear lights, but they are significantly brighter. Headlights are on in both pics.
Old 01-25-2018, 09:06 AM
macmac350's Avatar
macmac350
Nice, a lot of light.
Old 01-25-2018, 09:57 AM
jergle's Avatar
jergle
jergle is offline
Those little lights on the side are the best modification I've done to my truck. I've noticed that since the truck is so big and the front headlights are so far away, you really don't get much light to the side when making a turn. I was pulling my camper in a dark, unfamiliar campground one night, and when I swung out wide to make a turn, the side road completely disappeared! I love them, and use them every day.
Old 01-25-2018, 10:18 AM
BigSpenda864's Avatar
BigSpenda864
BigSpenda864 is offline
jergle, that's a good setup. I like the angled lights up front. I have power boards so I'm not sure how I could get that to look right but I'm going to check it out.
As for the actual reverse lights for the truck, are they already LED? I have a platinum trim truck so I have the LED from lights and what looks like LED lights around the taillights when the lights are on. Are the brake lights LED also in this truck? Are the white reverse lights? I've only had the truck for a couple of days and haven't had someone with me that could turn off and on lights while I stood outside to see exactly what is happening.
If the white lights aren't LED, you could probably get some replacement LED bulbs that would help a lot. Or if they are LED, maybe find some brighter ones.
Old 01-25-2018, 10:19 AM
BigSpenda864
Double post
Quick Reply: Aftermarket backup lights suggestions?
