Superchip1845 flashpaq
Old Jan 17, 2018 | 02:02 PM
krobbins's Avatar
krobbins
There is one for sale for $250 on a hunting website i frequent. Is this a good deal? I have a 2000 F350 SRW crew cab 4x4 Automatic. It kicks out of OD on some hills and not even towing anything, just long hills. I forgot to mention and forgot that I was pulling a 27 foot 5th wheel when it kicks out of OD and only goes back into OD on fairly level ground and around 60 MPH it goes back into OD. I guess I was use to my old Duramax and Allison Transmission that would not downshift unless I really got into throttle.
Old Jan 17, 2018 | 10:34 PM
Colorado350's Avatar
Colorado350
What are you hoping it will do? Sounds more like a transmission problem.
Old Jan 18, 2018 | 05:36 AM
Tugly's Avatar
Tugly
If you're looking for a chip to compensate for something in the truck that's not behaving the way it should, that's the exact opposite of a solution. Pushing the truck harder when it's ailing is like circling a date on the calendar to be stranded on the side of the road. Repairs can be way more expensive than a chip, but so is having a doctor set and cast a broken leg instead of just buying a splint.
Old Jan 18, 2018 | 05:52 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
There's nothing wrong with the programmer or the tuning written contained within.....
But these pickups shouldn't come out of 4th gear for any reason while unloaded on most any hill.
You didn't mention your speed when the transmission downshifts, but anything above 62-65 MPH takes quite a bit of accelerator pedal effort to force a downshift. My vote is a fuel supply issue, not a power issue.
Old Jan 18, 2018 | 07:12 AM
dn29626's Avatar
dn29626
I have been running a Superchip for years. It is to keep my transmission from fishing between D and OD.
It solved my problem.
Old Jan 18, 2018 | 08:28 AM
Brother Les's Avatar
Brother Les
I have been running a SuperChip for over 12 years.... (and I like it because I did not like the 'stock' setting)
What fixed my D/OD fishing was a new BTS.....
He has a transmission issue now and a Chip will/may only delay the inevitable.
Find the 'problem' 'at hand' and then go with a Chip if you want.
imo.
Old Jan 19, 2018 | 07:15 PM
krobbins's Avatar
krobbins
BTS?
imo.
I guess I don't know enough about these ford's to know what BTS is.
Old Jan 19, 2018 | 08:31 PM
crop harvester's Avatar
crop harvester
BTS Brian's Truck Shop in Arkansas,He builds custom Transmissions
Old Jan 22, 2018 | 08:05 AM
Brother Les
Brian rebuilt my transmission. He also installed a Shift Plate in the transmission to match the SuperChip tuner that I use.
E4OD | 4R100 | 5R110 Ford Diesel Powerstroke Transmissions
Diesel4me
Nov 16, 2006 10:37 PM
Craig64
17
Mar 19, 2006 02:42 PM
gordonh8r
Modular V10 (6.8l)
Mar 28, 2003 02:35 PM
