White Smoke
Old Jan 14, 2018 | 07:23 AM
Offshore530's Avatar
Offshore530
White Smoke
It may have been talked about but I’m on the road and the search function is not working on my phone. My truck is blowing white smoke at idle. It clears up but what is causing this. It’s the 6.7.
Old Jan 14, 2018 | 08:56 AM
wrvond's Avatar
wrvond
Are you sure it's not steam?
White smoke is usually caused by coolant entering the combustion chamber. Unless you have a cracked block, that's not likely on a new(ish) truck.
When it's very cold outside and the engine/exhaust haven't fully warmed up, white "smoke" is very common during idle. It doesn't come out of the pipe with any real force and quickly dissipates, while actual smoke would accumulate and kind of come out in pulses as the piston(s) with the leak force the gas out.
Old Jan 14, 2018 | 11:32 AM
Offshore530
It smells like **** too. It must have something to do with the DPF.
Old Jan 14, 2018 | 11:36 AM
ElectronPlumber's Avatar
ElectronPlumber
White smoke could be from a leaking EGR but like stated, kind of unlikely on a new truck.
Old Jan 14, 2018 | 02:03 PM
roadpilot's Avatar
roadpilot
Technically, if it's white, it's not smoke -- it's steam. That said:
Blue exhaust smoke = burning oil
Black exhaust smoke = fuel mixture rich
White exhaust "smoke" = coolant in combustion chamber
You'll get light white "smoke" early in the AM @ start up if you have condensation that has built up, but that shouldn't last for long.
If it's heavier white "smoke", don't drive it. Get it to the shop ASAP.
Old Jan 14, 2018 | 03:51 PM
Offshore530
I’m going to have the dealer look at it. My 2014 never had any stinky white smoke blowing out.
Old Jan 14, 2018 | 03:53 PM
Tom N OH's Avatar
Tom N OH
What does it smell like? Sweet? Sour? Smoky?
Old Jan 14, 2018 | 03:55 PM
Offshore530
Smells sour. One of my boats had a bad injector and white smoked.
Old Jan 14, 2018 | 07:07 PM
srkr's Avatar
srkr
My DEF smells like fresh bread. My 2011 was the same.
jorge.s
Feb 2, 2012 06:23 PM
rednek01
6.4L Power Stroke Diesel
32
Nov 29, 2007 09:57 PM
ceprice
4 Cylinder Engines
Sep 28, 2004 09:13 PM
mjnoakes
Dec 16, 2003 02:36 PM
GAPS-54
Nov 10, 2003 03:24 AM
