5.0 to 5.4 swap
Whet is your reason for doing this swap? A built 351W would get you some good power. The 392 moves my Bronco along pretty good. Personally, I don’t like the modular motors in a truck. The power band is too high up. From what I have seen posted from others, the mounts are the least of your worries. I guess the wiring is the bigger problem.
I have to agree with the wiring comment. I had a 2010 with a 5.4 in it. I loved the truck for the first few years but as soon as I hit 100k. I started dealing with major computer/electrical issues. The guy at my local dealership mentioned that my truck wasn't the first one he had seen with the exact same problems. The main issue was every warning light on the dash would randomly turn on while driving. It didn't cause any issues with drivability it was just super annoying. Also every time I took it in the tech couldn't "re-create the problem" so they couldn't fix it. My solution was to sell it to Carmax and go backwards to my 1993 F150. Couldn't be happier since I can now trouble shoot and work on it myself.
on
Yeah, motor mounts are the least of your worries. Did you check out how your right valve cover and the heater box both need the same space?
Get a new set of SBF perches from the JY and then put a 351 in it. Save yourself a huge hassle, since if you're asking how to make motor perches, I can only guess you don't have the mad skills to deal with intensive conversion wiring and troubleshooting issues relating to making all these new controllers work together.
Sorry to sound critical but I hate to see another OBS truck go to the scrappers after a failed swap.
Well, you'll need a manifold, $400 or so. Carb, another $400. And, you will need a stand-alone controller for the ignition, $900 or so. Also, you will need a transmission controller $800 and up if you stay with an automatic trans.
You can, however bust out another $311 + shipping for a set of adaptor plates to run a 4.6 2V carb conversion manifold on your 5.4 2V engine.
http://professional-products.com/int...er-adapter-kit
Man, that swap is getting even more costly by the minute.
No, it does not match up.
4.6L to 5.4L Spacer Adapter Kit - Manifold Accessories - Intake Manifolds
These guys have been making modular carb intakes since Ford introduced modulars:
Sullivan Performance Products
Sticker shock ain't the word for it.
