5.0 to 5.4 swap - Ford Truck Enthusiasts Forums
5.0 to 5.4 swap
Old 01-13-2018, 08:13 PM
Nmaykdm Nmaykdm is offline
Nmaykdm is starting off with a positive reputation.
5.0 to 5.4 swap
I'm going to swap the 5.0 out of my 1995 f150 to a 2002 5.4. Has anyone ever done this? I'm having trouble inventing motor mounts for it so if anyone has ever done this before I'd really like to talk about it
Old 01-13-2018, 09:15 PM
My4Fordtrucks's Avatar
My4Fordtrucks My4Fordtrucks is offline
My4Fordtrucks is starting off with a positive reputation.
Whet is your reason for doing this swap? A built 351W would get you some good power. The 392 moves my Bronco along pretty good. Personally, I don’t like the modular motors in a truck. The power band is too high up. From what I have seen posted from others, the mounts are the least of your worries. I guess the wiring is the bigger problem.
Old 01-13-2018, 10:02 PM
ROMAD0508's Avatar
ROMAD0508 ROMAD0508 is offline
ROMAD0508 is starting off with a positive reputation.
I have to agree with the wiring comment. I had a 2010 with a 5.4 in it. I loved the truck for the first few years but as soon as I hit 100k. I started dealing with major computer/electrical issues. The guy at my local dealership mentioned that my truck wasn't the first one he had seen with the exact same problems. The main issue was every warning light on the dash would randomly turn on while driving. It didn't cause any issues with drivability it was just super annoying. Also every time I took it in the tech couldn't "re-create the problem" so they couldn't fix it. My solution was to sell it to Carmax and go backwards to my 1993 F150. Couldn't be happier since I can now trouble shoot and work on it myself.
Old 01-13-2018, 10:03 PM
My reason for doing this because I blew up my 5.0 and I got a Triton motor for almost nothing and I already cut the motor mount brackets off to make it fit in there and the wiring doesn't seem to be issue for me because I plan to make it carbonated.
Old 01-13-2018, 11:55 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Quote:
You mean carburated. Have you looked for a carb intake for a 5.4?
Old 01-14-2018, 12:15 AM
Auto correct messed that up. Jegs gave me a part number for a carburated intake but I haven't looked at it or anything. I'm sure someone makes one
Old 01-14-2018, 12:30 AM
Conanski's Avatar
As far as I know there are no carb intakes for the 5.4.
Old 01-14-2018, 12:36 AM
raystankewitz's Avatar
raystankewitz raystankewitz is offline
raystankewitz is gaining momentum as a positive member of FTE.raystankewitz is gaining momentum as a positive member of FTE.
Well, you'll need a manifold, $400 or so. Carb, another $400. And, you will need a stand-alone controller for the ignition, $900 or so. Also, you will need a transmission controller $800 and up if you stay with an automatic trans.
Yeah, motor mounts are the least of your worries. Did you check out how your right valve cover and the heater box both need the same space?
Get a new set of SBF perches from the JY and then put a 351 in it. Save yourself a huge hassle, since if you're asking how to make motor perches, I can only guess you don't have the mad skills to deal with intensive conversion wiring and troubleshooting issues relating to making all these new controllers work together.
Sorry to sound critical but I hate to see another OBS truck go to the scrappers after a failed swap.
Old 01-14-2018, 01:09 AM
Thanks. Ill think about it now
Old 01-14-2018, 01:19 AM
Old 01-14-2018, 01:45 AM
does the intake off the dohc 5.4 match up to my ttiton? If so, they make a carburated intake for that
Old 01-14-2018, 02:53 AM
No, it does not match up.
You can, however bust out another $311 + shipping for a set of adaptor plates to run a 4.6 2V carb conversion manifold on your 5.4 2V engine.
http://professional-products.com/int...er-adapter-kit
Man, that swap is getting even more costly by the minute.
Old 01-14-2018, 03:02 AM
4.6L to 5.4L Spacer Adapter Kit - Manifold Accessories - Intake Manifolds
I started this project last year and I wish I didn't. I'd like to put the 302 back in it but I already cut off the brackets that hold the motor mounts on and not only was that a stupid move but I also threw them away and I'm sure they don't sell them anywhere or I'd weld them back on. What should I do now?
Old 01-14-2018, 03:05 AM
but this still leaves me without a carburated intake
Old 01-14-2018, 08:19 AM
Scndsin's Avatar
Scndsin Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
These guys have been making modular carb intakes since Ford introduced modulars:
Sullivan Performance Products
Sticker shock ain't the word for it.
5.0EFI to 5.4 Triton swap amr5080 1987 - 1996 F150 & Larger F-Series Trucks 19 01-13-2018 08:09 PM
4.6l swap to a 5.4l 3v RedSTX04 Modular V8 (4.6L, 5.4L) 1 08-18-2017 12:29 PM
5.4 to 5.0 conversion? medic2586 2004 - 2008 F150 19 03-09-2017 08:39 PM
Lightning 5.4 and non lightning 5.4 wa-sleeper Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 7 02-17-2017 11:32 PM
3v to 2v swap Jimmy Krizan 1999 to 2016 Super Duty 11 01-06-2017 06:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
