Low ect and eot?
Old 01-13-2018, 09:09 AM
kcjohnson78's Avatar
kcjohnson78
kcjohnson78 is offline
Low ect and eot?
Finally am able to see EOT on my 04 6.0 Ex. I’m disappointed in the edge cts and edge tech support as the cts will not show eot. Was told that it won’t monitor eot then see a ton of guys on here monitoring eot no problem? So for 40 bucks I bought a WiFi obd2 and got the app obd fusion and it has eot.
Anyway, it’s been cold here in Kansas City but ran around yesterday for about 30-40 minutes and my eot was about 176-178 and ect was 169 to 172 once warm. Delta was never more than 8 degrees. Are these temps too low? I have only had the truck 3 weeks. My first fill up I averaged right at 13mpg hand calculated. That was all City driving.
I bought a new 190 degree t-stat just don’t know if it really needs replaced. The truck runs perfect, oil and fuel pressures are good, egt is good, ficm voltage is perfect.
Old 01-13-2018, 09:43 AM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Sounds most likely to be thermostat. Others are finding the same problem in this global warming winter we are experiencing.
Old 01-13-2018, 01:18 PM
Chevota_72's Avatar
Chevota_72
Chevota_72 is offline
You could try blocking off part of the radiator with a piece of cardboard (free) or purchase a winter front ($$$) and try that. The fan is spinning at a pretty good clip even if the clutch isn't locked up. If you still have trouble maintaining temp then a thermostat is in order.
Old 01-13-2018, 02:19 PM
SmackDaddy's Avatar
SmackDaddy
SmackDaddy is offline
My 6.0 runs about 198 ECT/198 EOT even when it’s 24 degrees outside. Your thermostat may have some trash keeping it from closing so the coolant can’t cool the motor and warm up. If your temps are true that’s borderline engine operating temperature. How cold has it been when you are driving and getting these temperatures?
Old 01-13-2018, 02:45 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
The FIA cold weather front works great. Your t-stat is likely not closing, but if you are just driving around stop and go type traffic the 6L won't work hard enough to warm up either.. If you have both front and rear heat on high it will also let engine run cooler.
Old 01-13-2018, 03:52 PM
kcjohnson78
It was 17 degrees outside when I read those temps. However I have seen coolant not rise over about 178 at the highest. I have not done a Long highway trip yet, nothing over about 15 minutes at 70 mph. I need to make a long trip I guess and see what happens. We have a family trip in late February where I will have an 11 hour drive. Want to make sure I have everything squared away before then.
hi-jacker
01-14-2015 04:51 PM
CoalRollinX
03-16-2013 10:27 AM
66flareside
28
02-01-2009 05:15 AM
RyanJake
02-15-2006 07:09 PM
the law
01-06-2004 11:47 PM
Quick Reply: Low ect and eot?
